Wanted Holset HX30
Thread in 'Parts for sale' started by DarkBlack, Dec 7, 2012.
  1. DarkBlack
    DarkBlack Member
    anyone got one of these for sale? Need to be internal wastegated
    #1 DarkBlack, Dec 7, 2012
  2. john ps13
    john ps13 Active Member
    message lightning on here he's just removed 1 dont know what he's doin with it
  3. gaz_moose
    gaz_moose .MTM.
    yeah he has a hx30 with a 3" V band flange, setup to run an external wastegate, with the outlet pipe sorted if its to go on an SR then he has a 3" custom turbo elbow that will mateup to a regular downpipe.he has a silicone with a metal grate inside it that will bolt directly to a z32 afm,a correctly sized oil restrictor.
    so all you would need to fit it to an SR would be a generic top mount manifold,38mm wastegate and some oil lines.
    i was thinking of buying it off him but im to busy so would just sit in its box.i drove his car with it on and its a good turbo setup,punchy straight on boost with no lag and didnt tail off.
    #3 gaz_moose, Dec 8, 2012
  4. DarkBlack
    DarkBlack Member
    wanted to put it bottom mount on to my rb20... ill give him a shout. Thanks everyone! :)
  5. Sam H
    Sam H Troll Dispatch
    cheers Gaz. it's a good turbo. I think you should upgrade your green machine with it :-)
  6. DarkBlack
    DarkBlack Member
    still searching... *WITH INTERNAL WASTEGATE*
  7. SdR
    SdR Active Member
