Im selling this as i hardly get to use this anymore. It sits there most of the time begging to be used as it should. Specs 1982 E21 BMW 320/6 (still 320 on v5) E30 325i engine from a 2 door SE (had 108k on it when fitted) E30zone Wild Chip and K&N filter. 323i 5 speed. E21 320/6 flywheel (much lighter than E30 flywheel)/E30 325i clutch (new at the time of fitting the engine). 323i 3.46:1 welded diff E21 323i front brakes with green stuff pads SPAX PSX 60/40 suspension kit (adjustable damping) Whiteline front antiroll bar kit Doubled up rear antiroll bar K-MAC front camber/castor top mounts E30 projector non smiley lights BBS front spoiler Home made front strut brace Home made sump guard Spare wheel well cut out and plated over Interior Interior has been stripped apart from the roof lining, door cards, dash etc Floor tar sheeting all removed Drivers base mounted Recaro and passenger Ektor bucket seat Red four point harness on drivers side, standard belt on passengers Italvolanti steering wheel and momo boss Battery relocated and mounted in home made box sunk into the back seat area 6 point roll cage - needs mounting point reinforcement plates welding in as its just bolted at the moment Passenger foot rest Electrical cut out switch fitted but bypassed - bought it like this The car has 10 months TAX and 12 months MOT The car was mostly put together by its previous owner with the intention of it being drifted which it has been - its a drift car and as such please dont expect it to be of show car condition as its not. Its been 100% reliable apart from a slight misfire which only happens on damp mornings untill it gets up to temperature. Its most likely condensation in the dizzy cap causing the spark to earth. For the MOT it required a CV gaitor and had some welding on the underneath all of which was undersealed. The car also has a crack along the bottom of the windscreen but caused no concern. Im after £1350 for it, if you have any questions just pm me.
Im just looking for a cash sale at the moment. Forgot to mention, car is located near Aylesbury, Bucks.
