Right continuing the clearout of my spare stuff I have a WON minimax controller Full working order, allows you to turn your nitrous on progressively. After £100 plus £5 for uk postage. Also got a liquid filled bottle pressure gauge: £30 plus £3 postage.
Does the controller work with revs or simply just a progressive controller? I presume the guage is 52mm ?
The controller is a progressive controller switched on by a ground signal from a wot switch, ecu signal, or electric throttle position switch. It can't be set in a specific range unless you use an ecu output that can be programmed to do that. There is also electronic boxes on the market that will give you a signal within a rev range instead of a full ecu. The gauge is about 25mm. It is a simple bottle gauge.
Would you mind measuring the guage please, I've got q progressive controller so will have too pass in that
Si, that guage is connected at the bottle end, not for use in the car. its just to see how much is left in the bottle. You want: 52mm DIGITAL NITROUS PRESSURE GAUGE METER W. SENSOR | eBay for inside the car.
You can tee off the line from the bottle to the solenoids and fit it in the car but your right its ideally for reading the bottle pressure.
