1987 BMW E28 Turbo - M535i kit, Megasquirt - SOLD Hello guys, selling my "project" of the last few years No longer has airfilter in the headlight, back to 4x lights. Main bits are that it has a slipper, and spins the wheels through the gears at only 5psi with a very rich map. MOT until April 2017. Spec list is: • E28 Shell has had the jacking points welded up. 20% crusty, but fine. • Comes with full M535i Kit (getting rare!) • Stripped interior, alloy door cards fitted as door innards removed. • New battery relocated to boot in a cage • Corbeau Bucket Seats (drivers seat is on a rail suited for 6ft) • TRS 4 Point harnesses • Bolt on Arches • Lexan Polycarb front windows with sliders • Fully polybushed suspension • Spax dampers / Blistein springs • Megasquirt v3.57 • AEM wideband o2 sensor & gauge • Ford EDIS coil pack • Cometic Metal Headgasket • ARP Headstud kit • New Garrett GT3271 Turbo /w External Waste gate • Very rare BMW cast log turbo manifold – flipped for top mount • Oil Catch Can • Front mount intercooler • Bosch 440cc Injectors • Adjustable fuel pressure regulator • Walbro 255L Fuel Pump • M5 rear large case diff • Brembo callipers with new 330mm discs • Dare RS 17x8.5 wheels & new tyres 225/45 SOLD
Hi Mate, This looks epic! Whats the body/paint like? what sort of power does it make? How does it drift? Any issues with the car?
Thanks for comments. Yes M30B34. Should make about 350whp with 1 bar of boost (comes with the WG spring) S14rob, paintwork is ok. It originally had a fibreglass arches that got damaged, so were pulled off. Rear has been properly tubbed with inner and outter skins being welded together & seam sealed. The arches is prob the worst bit. Did plan of smoothing everything out and painting it RAF Blue, but have not got round to it. All runs well, it has a primitive map on it that I created with tunerstudio, it runs rich 10:1 under boost, so needs a proper tuning session. We had some fun doing this as we went out on a wet night, and just ended up with wheelspin (even @ 70-80mph on the motorway in 3rd) I'd knock a few quid off for a DW member
