For Sale 1990 R32 4DR GTST PROJECT
Thread in 'Drift cars for sale' started by connorqueen, Jun 5, 2019.
  1. connorqueen
    connorqueen Member
    Falkirk
    Imported in 2003
    Selling this as I no longer have the time to finish it. Was building it with intention of turning it into a competition drift car. The car was fully stripped to a bare shell and redone from the ground up. All welding repairs were carried out and the full under side coated with 2 coats of underseal. Nearly everything has been refurbished or renewed. Full welded in BDC spec roll cage done by miller mods. It can all be seen on my Driftworks build thread - https://www.driftworks.com/forum/threads/4dr-r32-rb25det-neo-bdc-spec-build.257771/
    r32.
    r32a.
    r32w.
    Spec –
    RB25NEO (compression checked)
    GT35 REP Turbo
    Top Mount Exhaust Manifold
    Front Facing Inlet Plenum
    NEW HKS Timing Belt and OE Water Pump
    NEW Auxiliary Belts
    NEW Short Shifter
    NEW Competition Clutch, Master Cylinder and HEL Braided Clutch Line
    NEW Competition Clutch Lightened Flywheel
    NEW Nismo Engine mounts
    GTR injectors
    NEW Oil cooler and thermostatic sandwich plate
    NEW Fuel Pressure Regulator?
    NEW Walbro 255lph fuel pump
    Turbosmart external waste gate
    NEW Alloy Radiator
    NEW Twin Electric Fans
    NEW Driftworks Polybushes
    30mm Extended Front Lower Arms
    “HeyGlen” Modified Front Subframe
    NEW Super Pro Steering Rack Bushes
    NEW Adjustable Suspension Arms
    NEW Hicas Delete Kit
    NEW Driftworks Geomaster Hubs
    NEW Front Wheel Bearings
    NEW Solid Rear Subframe Bushes
    NEW Solid Steering Column Bush
    NEW HEL Braided Brake Lines
    Full BN Sports Kit
    Will come on VOLK wheels not the rotas as pictured in the build thread
    That’s as much I can remember of the top of my head. This is to go a complete package, I WILL NOT SELL BITS SEPERATELY. We’ve had the car running very briefly to test the wiring loom. The engine loom just needs tidied up and fiited properly. All other wiring is back in the car. Oil cooler and Heater matrix. Will need some form of aftermarket ECU but we had it running on the standard ECU. Everything else is mostly cosmetic. Will come with all panels and doors etc that were on the car and even the original interior.
    Looking for £7000ono. In no rush to sell and if it doesn’t I’ll finish it one day
    Located Falkirk, Scotland
    Will need trailered away
    Any questions feel free to ask, call or text me on 07969980220
    • Like Like x 2
  2. connorqueen
    connorqueen Member
    Falkirk
    Bump £6500ono
  3. connorqueen
    connorqueen Member
    Falkirk
    DEPOIST TAKEN
  4. drift-nut
    drift-nut Member
    bristol
  5. connorqueen
    connorqueen Member
    Falkirk
    Sold
