Selling my ps13 imported from japan wich was used in the D1 Streetlegal class. Exterior is good used and needs some attention. technically its perfect, engine is running great. Speclist: Engine: Tomei Poncams (IN/EX 256 11.5mm lift) Tomei rockerarm stoppers Tomei IN/EX Adjustable pully's Tomei A type Valve springs Tomei Epreme Elbow Tomei Epreme Downpipe Tomei Triangle Tower bar HKS 1.2mm Headgasket HKS S-type FMIC Thrust Grex Oil relocator Thrust Grex 10 Row Oilcooler Yashiofactory two layer copper radiator Billion 68 Degrees Thermostat HKS Spark Plug cover HKS Exhaust Manifold (3mm Thick reinforced) ARC Enlarged Oil pan +850cc CUSCO Oil catch tank 1L HPI Engine Damper URAS Cas Cover APEXI AX53B60 Turbo Only 5000KM old APEXI Intake APEXI Super suction kit APEXI Race decat APEXI GT-Spec Radiator cap (1.3kg) SAMCO Radiator hoses Trashracing covers on top of headlights Z32 AFM NISMO ENgine mounts SARD 555Cc Injectors Carbing light cooling panel R32 GTR Fuel pump APEXI Power Fc + Hand commander + boostcontroller Cylinder Head Flattened (Correction of 1/100) Cylinder head checked and rebuild Inlet ports and exhaust ports ported Nismo rod and main bearing set O/S Oversize Pistons and Piston link Set 380HP @ 1.5bar Boost Exterior: 3D Carbon GT-wing with SARD Aero side blades 180sx Side steps OEM Trash racing Bonnet Pins Rolled Rear fenders BELLOF HID Xenon kit Sparkling white 6000k Shop Original Side clear marker lights Shop Original Front/Rear Clear chrome corner lights Shop Original New s13 eurotail lamps Shop Original Carbon Eye liners Shop Original Roof Spoiler Shop Original Carbon side panels Granador Carbon Mirrors Front grill maker unknown Wedsport TC005 wheels 16x8 rear 16x7 front Wedsport Wheel nuts Yokohama ad08 semi slicks Eurolite Neon Rising LED Wheel brite panels Nismo Fuel cap Interior: Trash racing Street Alpha Full Bucket seats Trash racing Quick Release with boss spacer (30-60mm can be changed) Rear seats Removed and Repainted to match body color Sabelt Clubman 4 point seatbelts Genuine Nissan optional kneepad Genuine Nissan Boot pads Nismo Shift knob Nismo Alumi shift pattern panel Nismo Fashion Cigar lighter All wet carbon interior parts bought from Final Konnexion GarageSolution Carbon style center column cover Shop Original Door switch panels Shop Original Door Doorhandle panel Shop Original Dashboard vents and ashtray carbon coating Shop Original Carbon Mirror cover Shop Original carpits Origin Carbon Door panels Momo Fighter steering wheel and horn Button Sony 1 din/cdrom Radio RayBlic Room ligths Rear all windows Purple film Apexi Earthing PIVOT 80mm Mechanical Boost gauge Apexi multi checker Apexi Rev/Speed meter Horn made by mitsuba Vertex Dry carbon Window Visor Veilside Pedals CUSCO 8 point Cromolyrolcage. Brake system: R32 Gtr Front calipers Racing Gear 6split Disk rotors Axis Racing brake pads Drive Train: CUSCO Twin plate Reinforced clutch (Crimp force 1000kgf) NISMO R200 LSD 2 way Differencial R33 Gtst diff and shafts Shortshifter Suspension: CUSCO ZERO-2 R (Front 7kg/mm Rear 5kg/mm) CUSCO Camper arms Cusco Rods rear Nismo upperlink arm Nismo Front lower arm Nismo Front tower brace kit ARC Adjustable Front and rear Anti roll bars abd bushes Tein Reinforced Tie-rods With upperspacer Tein Tie rod ends OEM Rear under arms Price: 9750 pounds. Swap with something with JZ possible Located in The Netherlands. For more info drop me a PM {} {} {} {} {} {} {} {} {} {} {}
