{} {} {} {} {} {} {} 1993 Toyota Soarer 1jzgte running approx 500bhp Factory non abs R154 manual Lsd Ecu master emu black Wideband sensor (for ecu control) Holset hx35 on top mount manifold w/external wastegate 4inch intake with massive proram air filter Front mount intercooler Alloy rad 550cc injectors Walbro fuel pump Brand new uprated coil packs Ls400 discs & callipers Full 3inch exhaust from turbo to a single generic jap can muffler Screamer pipe Auto couture skirts and rear bumper Currently waiting to have a brand new set of meister r coilovers & coil covers fitted ready for the new owner Mot until end oct 23 Car is currently running about 500bhp I have a dyno printout from the previous owner but it has since had new uprated coil packs (old ones cracked) and a much bigger air filter (existing one was wayyy to small and choking it) and a few minor adjustments to the mapping at the same time I was told that with some larger injectors the setup should be capable of more power Sitting on roughly 132000 miles, gets driven regularly so this will go up The car originally started life as an auto but has been manual swapped with an R154 gearbox and has also had the correct ratio lsd fitted aswell so speedo is accurate Points to note: The Nardi steering wheel will not come with the car Generally the paint is tired Please zoom in on the photos, the clear coat has failed on the bonnet and boot (is not peeling unsure what happened) The roof has been repainted at some stage but isn’t a very good job The car came with the bucket seats therefore I do not have the originals to go with the car (they hold me well enough but not to my personal taste) The right hand centre vent has some broken fins Price will be £15750 on the veilside Andrew’s £14000 on a set of generic 19s it came with ( tyres are absolutely shité tho and haven’t currently tested if they clear the ls400 callipers) with all due respect test drives will only be allowed with valid proof of insurance located in Camborne Cornwall
To my knowledge it’s an act 6 puck, I’m unsure of the flywheel as it was the previous owner who had converted it
