I'm selling my project, i have it for 3 years. The car has no rust and has had thousands spent on it. This is fast 328i with BIG SPEC Full spec: M52b28 M50 inlet manifold M3 manifolds, full M3 exhaust with decat Dave F induction kit Air Con delete Viscous fan delete , electric installed Remapped ECU, advanced timing to match shell V-power , 7000 rev limit with exhaust pops and bang Engine is really strong. M20 flywheel (single mass machined down to 5kg) paddle clutch and reinforced pressure plate also has M20 starter motor to suite. Solid Gearbox Mounts Medium Case LSD fully rebuilt with 4 clutch 40% lock and 3.71 final drive Poly Rear Subframe bushes. Full cooling system flushed with new coolant. New spark plugs and all filters changed. Acceleration video exhaust pops and bang CAE Shifter Suspension: Bilstein B16 fully adjustable coiovers E46 front arms with fresh tie rods and LOCK ADAPTERS Rear subframe re-bushed with polyurethane bushes Eibach Anti-Roll Bar Kit Front 26 mm 2 way Adjustable And Rear 22 mm 2 Way Adjustable Rear trailing arm bushes replaced with polyurethane New battery Air con delete Ultra Racing front and rear strut brace Interior: Fixed Bucket Seat Rails Sparco Drivers seat OMP Velocita Superleggero Steering Wheel (genuine) CAE Shifter Hand brake with new pump Wilwood Brake Proportioning Valve - Lever Adjustment Brakes: Front and rear drilled discs with ferodo ds2500 pads Wheels: 17x7j ET37 Tyres: Front - 205/40/17 Nankang NS2/R Rear budgets Car is load legal, insurance cost only £200 per year. Located in Greenford UB6 Please contact me on 07456071387 Price £3400
