1998 BMW M3 Sedan Current registration / Clean title S52 5speed M3 ZF (Fresh fluid) Dinan short shifter 3.23 Limited Slip Differential (fresh fluid) Megan Coilovers Brand New DKM clutch kit E46 Control arms with SLR Lollipops Seibon carbon fiber hood Comes on contours with good tread Fresh brakes extended stud conversion New windshield New wheel bearings All brand new Garagistic 80a Polyurethane bushings for sub frames, control arms, differential, transmission and motor just installed Fresh shifter selector rod, bushings cup and steel clutch pivot pin. Detent kit freshly installed on Zf M3 trans Parts Dmax Chassis reinforcements kit installed Parts dmad front strut bar Megan rear strut bar Xcessive trailing arm mounts Adjustable battle version arms Adjustable front and read ground control end links Recent alignment Fresh stewart high performance water pump AN Power Steering Kit Fresh valve cover gasket with oil change. Differential and trans fluid just changed. New Air filter Cleaned MAF Brand new ebrake shoes and tensioned cable Msport trunk latch reinforcement I had the car built as a reliable and comfortable daily/track hybrid. Includes extra rear M3 axle pair Zero overheating after long car trips or testing out the LSD. Asking 13.5k obo {} {} {} {}
