For Sale 1JZ-GTE VVTi, all ancil's, JZX100 FMIC, SARD FPR & more!
Thread in 'Parts for sale' started by WheelRubber, Jun 8, 2018.
  1. WheelRubber
    WheelRubber Member
    Devon, UK
    UPDATED 19th November 2019
    If there are things that arn't in the list below, send me a message and ill see if I still have it. This post will be updated as often as possible, but if you want a quick answer, message me on 07872945688.
    Payment and postage rules - All payments are to be made by either BACS or cash on collection. No paypal malarkey as they charge me fees (my only PayPal account is a business, so the fees get charged regardless of friends/family payments). I can be found on Facebook and am known by many of the big named drifters out there, so wont be doing anything to "sting" you out of money. Postage is accepted as long as YOU pay for and arrange it. You pay for it, send me a label and ill pack it/ship it.
    The Sales List (constantly being updated) Photos will be added asap
    Toyota 1JZ-GTE VVTi Engine Tall block - comes as a closed and fully built tall block with oil dropped on 08/06/2018. Rebuilt in August 2017. Machining done at Classic & Modern Engine Services in Bracknell, Berks (invoice goes with engine). Will not come with anciliaries, but an amazing block ready to take some huge power and a beating.
    Spec is as follows:
    - Deep clean block, head, pistons and valves
    - Check piston-bore clearances
    - Honed all 6 cylinders
    - Lapped valves
    - Reface head
    - Reface block
    - Replace/renew core plugs
    - Check rod housing and recircle caps
    - Crankshaft reground by 0.25mm and balanced
    - New Toyota OEM Gasket kit including Head gasket, stem seals, front and rear crank seals + more...
    - New Toyota OEM Water pump
    - New Toyota OEM Oil pump
    - New Toyota OEM Timing belt kit
    - New ARP Main studs and nuts
    - New ARP Big end bolts
    - New Kings Racing Main bearings
    - New Kings Racing Conrod bearings
    - New Kings Racing Thrust washers
    - New Toyota OEM Ring set, gapped to 0.024" and clocked as per OEM Spec.
    - Rebuilt using Lucas Oil Stabilizer and LiquiMoly 10w60
    £1,750.00 --- Collection preferred, but could pallet and ship if you pay for a pallet and arrange collection. Willing to consider leaving all the ancilaries on it for the asking price, and will take an offer on just the tall block.
    Sard Fuel Pressure Regulator with braided Inlet & Return fuel rail lines - Built and fitted brand new by MB Automotive in March during mapping to give the Sard's what they needed.
    £240.00 --- Happy to ship at your cost.
    JZX100 Manual Clutch Pedal assembly and Master Cylinder - Brand new Toyota OEM parts. Comes with a 2 metre braided line for easier on/off box jobs at the slave end.
    £300.00 --- Happy to ship at your cost.
    20170807_154615.
    #1 WheelRubber, Jun 8, 2018
  2. WheelRubber
    WheelRubber Member
    Devon, UK
    JZX100 Rear Light Clusters - I believe these are called the Type 2's? Anyway, I always preferred this design to the other ones. Both in perfect working order, with wiring ready for fog and reversing lights. --- Price - £200.00 --- Happy to ship at your cost.
    20180618_121030.
    1JZ-GTE VVTi Stock Inlet Manifold - Good condition, not knocks or dinks. --- Price - £60.00 --- Happy to ship at your cost.
    1JZ-GTE VVTi Stock Throttle body - Good condition, works perfectly. --- Price - £40.00 --- Happy to ship at your cost.
    1JZ-GTE VVTi Engine Wiring Loom - All wiring is in place from the Automatic, so you could remove some of it, but it has just been unused and cable tied out of the way during my use.
    1JZ-GTE VVTi Stock Coil Packs x3 - In perfect working order. Never had any problems with them. --- Price - £75.00 --- Happy to ship at your cost.
    1JZ-GTE VVTi JZX100 Stock Automatic ECU - Worked perfectly before replacing with PowerFC. --- Price - £80.00 --- Happy to ship at your cost.
    JZX100 Stock Fuel Pump - In perfect working order. Could do with a new filter sock. Only replaced due to bigger pump. --- Price - £30.00 --- Happy to ship at your cost.
    JZX100 1JZ Front mount intercooler with piping and clamps - Brand new, been fitted but never ran whilst fitter. Really nice fitment though.
    £240.00 - Happy to ship at your cost.
    Stock JZX100 Radiator - Used, but in good condition. No leaking or cracking.
    £50.00 - Happy to ship at your cost.
    Front DMax 35mm Extended wings - From EPRacing about 3 months ago. Brand new and unfitted. Really nice look on these.
    £200.00 - Happy to ship at your cost.
    Stock JZX100 Front Headlights - Good condition and working. Lugs have snapped in usual place, but never bothered me, hence price.
    #2 WheelRubber, Jun 8, 2018
  3. WheelRubber
    WheelRubber Member
    Devon, UK
    Stock JZX100 Front door cards - ---SOLD---
    Rear ARB D-Clamps with bushes - ---SOLD---
    Aftermarket Alloy Radiator - ---SOLD---
    Borg Warner S300SX 66mm T4 Turbo - ---SOLD---
    JZX100 TRD Front Strut Brace - ---SOLD--
    Stock 1JZ-GTE VVTi viscous fan - SOLD @ £70.00
    JZX100 Solid rear diff mounts
    - SOLD @ £50.00
    19 Row Oil Cooler & Oil filter relocation kit - SOLD @ £250.00
    Battery relocation kit
    - SOLD @ £125.00
    Stock JZX100 Front seats with Rails
    - SOLD @ £0.00 with Shell
    Throttle ECU
    - SOLD @ £50.00
    OEM Amber side lights
    - SOLD @ £80.00
    OEM Fan Shroud - SOLD @ £50.00
    Full FibreClass body kit, including front/rear bumpers & skirts - SOLD @ £300.00
    Front TRD Grill - SOLD @ £80.00
    Boot Trim x2 - SOLD @ £40.00
    Walbro 455LPH Intank Fuel Pump - SOLD @ £0.00 with the Shell
    1JZ-BMW Manual Adapter/Conversion Kit - SOLD @ £1,300.00
    JZX100 Rear Drive Shafts x2
    Welded 4.1:1 Auto Diff - SOLD @ £0.00 with the Shell
    Toyota Chaser JZX100 Road legal Rolling Shell with V5c Registration P522CCT
    - SOLD @ £1,800.00
    JZX100 Rear DMAX Window Spoiler
    - SOLD @ £130.00
    HKS Hi-Power Full Cat-Back Exhaust system - SOLD @ £400.00
    #3 WheelRubber, Jun 8, 2018
  4. woolleyman
    woolleyman Member
    Sudbury, Suffolk
  5. WheelRubber
    WheelRubber Member
    Devon, UK
    Replied :)
  6. Rubix_Cube
    Rubix_Cube Member
    Kilmarnock, Ayrshire
  7. WheelRubber
    WheelRubber Member
    Devon, UK
    Responded
  8. WheelRubber
    WheelRubber Member
    Devon, UK
    Happy to take offers on stuff as need the cash out of this asap!
    • Informative Informative x 1
  9. Ooomoo
    Ooomoo Active Member
    Any seats with runners?
  10. WheelRubber
    WheelRubber Member
    Devon, UK
    Yep, have both front seats with runners and airbags intact. PM me with your offer as not a clue what I should ask for them?
  11. Ooomoo
    Hi buddy could you fire me some pics plz of the front sests :)
  12. WheelRubber
    WheelRubber Member
    Devon, UK
    Will do. Fire me over your mobile number in a private message and ill send them tomorrow on whatsapp
  13. Ooomoo
  14. WheelRubber
    WheelRubber Member
    Devon, UK
    Got it :)
  15. Ooomoo
    When you sending me pics lol..
  16. WheelRubber
    WheelRubber Member
    Devon, UK
    Sorry bud, havent had time to get to the barn last couple of days. Hope to have the photos tomorrow/monday
  17. WheelRubber
    WheelRubber Member
    Devon, UK
    Refreshed and dropped all the prices!! Get yourself a bargain while you can!!!
  18. t2901
    t2901 Member
  19. WheelRubber
    WheelRubber Member
    Devon, UK
    Got it
  20. Ooomoo
