1JZ hydro fan question
Thread in 'Technical Questions' started by Kenji, May 13, 2010.
  1. Kenji
    Kenji Active Member
    Rotterdam, The Netherlands
    I recently bought intake pipes so each turbo has it's own intake pipe and filter.
    But the pipe that goes onto the front turbo hits the hydraulic fan pump.
    If I fit an electric fan, can I remove the pump? Anyone did this and wants to share how he did it?
    The pipes:
    The small pipes hits the pump assembly at the spot where the small black nipple is (I already removed that)
    The pump assembly is visible here, in the bottom.
    And in the picture below it's visible too, beneath the waterneck (2 braided lines)
    It's the thing with the big black rubber hose attached to it, and the "tube" above it.
  2. Ysracing
    Ysracing Active Member
    can you tell me where can i get one of them clear cam cover.
  3. zombie
    zombie Active Member
    gloucester
    +1 please, sorry to hijack
  4. Kenji
    Kenji Active Member
  5. Ysracing
    wor...its 97 pounds !!
  6. Dylan
    Dylan JZS14FTW
    cheam/sutton
    if you referring to the water pump, no you cant remove it. the only way around this is to remove the whole water pump and replace it with a non-hydro water pump, and fit a viscous or electric fans.
  7. Kenji
    Kenji Active Member
    Crap. Guess I'll just have to butcher the pipes and re-weld them....
