I've got plenty of bits that you can "borrow" to try IF you can get the motor to me. I'm currently without wheels as both cars are having work on otherwise I'd pop down and see you. I'd be perfectly happy to give you a bit of my time one weekend to go over the car with you.
cheers buddy, by the looks of things, my tax/reg documents will turn up monday/tuesday So that gives me up untill the weekend to try regapping the plugs and if that doesn't work then chucking on Bens coilpacks to see if it's them. If none of that works thenI'll bring the car to you one day next week to swap some bits over. Gunna be so much easier to isolate the problem with another 1jz right next to it, saves buying bits that aren't the cause. Should sort it in no time. My best mate is taking his new 86 to you for a 20v swap anyway
Ah right..yes indeed. He's coming in a week Saturday. I imagine it is coil packs if they've been getting wet. If I remember correctly the coil pack cover wasn't on that engine was it? The cover would stop water getting into the coil packs.
My coil cover was on, but it being vented as well as my carbon hood, the water was getting in, what Jamie said about the water and crap insulating the old plugs masking the coil problem a bit is starting to make sense. Wouldn't be surprised if I found cracks on the underneath of the coils when I pull them tomorrow Fingers crossed ey!
Maybe a bit late, but Id go for coil pack clips first, then coils. Ignitors do go but its not that common. Oh and new coils are 96 quid each from Toyota, x6 Supersparks are about 350 for a set from Whifbitz, Im using them in my big single Aristo.
Where the loom plugs into the coil pack, the grey connectors? They get brittle with the heat, then all busted up internally so they dont connect properly. In my JZ experience thats the number 1 cause of missfires, Ive had it on 1 and 2JZ. new clips are 30 odd quid from Toyota.
Well thats not gonna help is it lol. If you choose to fit the clips Ive done a how to guide on clubaristo
Here you go mate, its easy, obviously the important part is to get the cables the right way round lol Club Aristo
Ok misfire isn't cured but a hell of a lot better after gapping the plugs down to .7 (the car actually boosts now, only starts missing when approaching full boost) So gunna chuck in some iridiums at .7 and try another set of coilpacks. If that doesn't work then look at the earthing to the coilpacks and possibly replacing the connectors. But definitely a step in the right direction.
I am only running stock boost though? Will try .6 when I get the iridiums on the weekend Before trying the new coilpacks
I've had a similar issue, your not gonna like this but I reckon it's worth doing a compression test just for peace of mind. I've had a similar issue and spents hundreds on plugs, coilpacks, new clips, fuel pump, fuel filter etc and now I suspect it's a more terminal issue. All the best mate, loads of us are fans of your car and i'm keen to hear of it up and running properly
compression testing is always a good idea, but something has gotta be pretty drastically wrong with an engine for it to cause a misfire, id be suprised if it was that
