1JZ Non VVTI Engine for sale
Thread in 'Parts for sale' started by James Flanagan, Feb 3, 2024.
  1. James Flanagan
    James Flanagan New Member
    **WILL SWAP FOR COMPLETE M3 3.2 ENGINE**
    1JZGTE Non VVTI Engine with 77,000KM Purchased from Nippon Autospares. Tested before purchase. Comes with ECU etc so everything for a conversion
    Brand new and unused JAPSPEED 1JZ NON VVTI 3mm STAINLESS T3 + EXTERNAL WASTEGATE EXHAUST MANIFOLD fitted Brand new and unused
    Holset HE351W 12cm Turbo. Hybrid of HX35 and HX40 Turbo with T3 Twinscroll. Capable of 600+HP Single turbo oil line kit new and unused. Not fitted
    Adamat conversion plate to Getrag 420G Gearbox plate with Toyota 1JZ 2JZ GE GTE 650 - 900N TWIN PLATE CLUTCH TO BMW GEARBOX ADAPTOR CLUTCH KIT - CLUTCH STAGE : Stage 2 Fitted to the engine and unused
    1JZ to BMW E36 engine mount conversion kit new and unused
    1JZ 2JZ GE GTE CUSTOM REAR OIL PAN/SUMP KIT SWAP E36/E46/Z3/Z4 new and unused and not fitted with bolts
    Comes with original twin turbos as well The engine was for a project that didn't go ahead. The engine has sat in the workshop for 6 months and though unused the clutch plate etc has got surface rust. It never got fitted to the vehicle.
    The first pictures are of the engine having everything mounted the later ones are as it is now with the surface rust on the clutch plate. There is around £6,000 of parts here and ready to go for converting an E36 to 1JZ with big power. Can pallet deliver.
    IMG_20230629_094450.
    IMG_20240202_151859.
    IMG_20240202_151908.
    IMG_20240202_151916.
    IMG_20240202_151943.
    IMG_20240202_152044.
    IMG_20240202_151927.
    IMG_20230629_092943.
  2. trebor69
    trebor69 Member
    Isn't that Japspeed manifold on upside down?
  3. James Flanagan
    It was just put on with one bolt to keep it all together and out of the way. It catches a water pipe when on the correct way.
