Hello everyone, yes i have searched but no luck finding diagram or pin out basically I am swamping 1jz non vvti in to s13, I have found some info that there is around 7-11 wires that i need to connect to get the engine running in the body, like igniter, fuel pump, battery and etc. by any change anyone have pin out diagram or any info that can help me ? thanks
depends on the wiring loom you're using. if it's jzz30 then use wilbo666's wiring manual http://wilbo666.pbworks.com/w/page/47216384/1JZ-GTE JZZ30 Soarer Engine Wiring sėkmės
Does the S13 have the F4 chassis pinout diagram? Its normally an easy task, you get the ECU pinout diagram, and a chassis loom pinout diagram and connect the dots for everything that needs 12v perm, 12v switched and earth. Job done
