1jz non vvti into 180sx wiring !!!
Thread in 'Technical Questions' started by Danimaldrifter23, Oct 21, 2018.
  1. Danimaldrifter23
    Cornwall
    Does anyone have a diagram or know how too wire a standard wiring harness from a 1jz-gte non vvti into my 180sx .. any help will be appricited . Thanks
  2. Danimaldrifter23
    Cornwall
  3. Danimaldrifter23
    Cornwall
  4. Shire Motorsport
    Cirencester
    Also intrested in this
  5. scotiasx
    scotiasx Active Member
    west coast scotland
    Are you doing the work yourself?
    I put a 1jz into my s13 a good few years ago and using “wilbo’s“ ecu pinnouts managed to do all the wiring myself, it was surprising how little wires it takes to get the engine up and running.
    http://wilbo666.pbworks.com/w/page/47216384/1JZ-GTE JZZ30 Soarer Engine Wiring
    I assume you already have or can get the 180sx harness wiring?
    It’s as simple as mating the two and obviously going as in depth with whatever you do or don’t want to work on your dash
    I did wire up my own separate fuel pump supply and switch. And used the Nissan starter relay and charge signal wires.
    If you need a hand or further info drop me a pm and I’ll help you out some.
  6. scotiasx
    west coast scotland
    Also if you do a quick search on here I’m sure I used some of “daleb” advice
  7. Shire Motorsport
    Cirencester
    Do you mean 180sx engine or interior harness pal I have interior but no engine harness went on my sr20det
  8. scotiasx
    west coast scotland
    So you don’t nesseserally need the 180sx engine harness. But you’ll be tapping into the white plug under the dash above the blower motor for anything you want to hookup to your original dash.
    http://56.akszer.eu/nissan-180sx-wiring-diagram.html
    It would be nice if you still had the loom to take all your power feeds for your igniter, injectors and sensors from your standard relays that are there ready to use. But again not nessesary.
