For sale! Extremely good condition Exedy Hyper twin plate clutch for the 1JZ engine to r154 box, Hasnt done to many miles and really hasnt had that much abuse as its not been in the car to long, but im going a different route now so its up for sale! Has had a brand new bearing and sleeve and all clips etc before i put it in. Comes with lightweight flywheel Pictures below; First plate 3.533mm Second plate 3.533 And a not very good photo of the flywheel Specs off the website: [TABLE="class: specs_table, width: 778"] [TR] [/TR] [TR] [TD="class: specs_title"][/TD] [TD="class: specs_value"][/TD] [/TR] [TR] [TD="class: specs_title"] Clamping Force/Load exerted (lbs) [/TD] [TD="class: specs_value"]2248[/TD] [/TR] [TR] [TD="class: specs_title"] Disc Material [/TD] [TD="class: specs_value"]Ceramic[/TD] [/TR] [TR] [TD="class: specs_title"] Number of Disc [/TD] [TD="class: specs_value"]Twin[/TD] [/TR] [TR] [TD="class: specs_title"] Type (Push/Pull) [/TD] [TD="class: specs_value"]Pull[/TD] [/TR] [TR] [/TR] [TR] [TD="class: specs_title"] Clutch Torque [/TD] [TD="class: specs_value"]937 [/TD] [/TR] [TR] [/TR] [TR] [/TR] [TR] [TD="class: specs_value"]Some more information on them (NOT MY AUCTION/OR SALE EBAY LINK) EXEDY JAPSPEED JZX90/JZX100/JZX110 CHASER 1JZ-GTE HYPER TWIN PLATE CLUTCH KIT | eBay Looking for £1000 posted UK mainland can post international at buyers expense.[/TD] [/TR] [/TABLE] Also have a full R154 conversion (box, bell housing, slave cylinder, clutch fork and all bolts etc, box has damaged third gear) Post will be made for this ASAP. Can do a deal on it all. Link to post, http://www.driftworks.com/forum/par...der-remote-shifter-all-bolts.html#post2498433
Hey can you put some more pictures up please Pics of all plates both sides, separate images of the same with a ruler across them and pictures of some digital calipers showing the size of each disc if I recall I think plates new are 4mm ish Cheers Marc
When I'm next there pal I will get it off and try get some photos! I don't have any digital callipers mate but I'll make them as clear as I can, I was running 400bhp at wheels on it and it's never missed a beat
not a problem, would be good if you could lend some calipers off someone to measure the plate thickness for me cheers
