1jz s13
Thread in 'Drift cars for sale' started by treadmill, Aug 4, 2015.
  1. treadmill
    treadmill Member
    Right im selling this for my friend he no longer wants it, can never make up his mind, so dont message me that you think it over priced ect.
    Engine had a refresh before fitting, new stem seals, good clean up, factory new front sump setup , rocker covers coated anthracite, drift motion intake mani. Mocal oil cooler kitMade the exhaust myself. 40mm ally rad. Hks lm intake . Apexi avcr, jzx manual ecu. Regularly serviced
    Walbro 400 in tank pump, through car lines. Nismo fp regulator
    Tubed front end, hsd coilovers, dw front lower arms, dw tension rods, tein steering arms and ends, rack spacers , stainless steering bush. Apexi rear arb and drop links . Welded rear auto diff. Solid subframe bushes. All rear arms have dw Polly bushes fitted.
    Cusco 6pt through dash cage.
    K-sport 330mm front discs on sumitoyo ally callipers ds2500 pads
    Standard rear breaks on brembo disks
    Hell performance break lines, new copper lines from master to t-pieces. Abs delete.
    Master cylinder lines all heat jackets fitted
    Hell performance master to clutch slave line
    Sparco rev 2 seat on omp rails, lightweight battery fitted behind drivers seat, on battery isolation switch
    Takatta harnesses. Seat and harness still In date
    Advan sar3 17x9.5 and 8.5 recently refurbed gloss black
    Nankang ns2's (brand new) up front and ditch finders up back
    Inside fully striped back of sound deadning and properly sprayed black.
    20mm front carbon fenders
    Carbon boot with plastic screen
    Has digital dash
    Mot till end of year
    Doesn't have power steering but have been collecting parts to refit, like belt, 350z power steering pump, aircon pump ect
    £7000 chichester west sussex 07747146320
    #1 treadmill, Aug 4, 2015
  2. Ruishy1
    Ruishy1 Active Member
    East Ayrshire
    how can we say its overpriced, when there isn't a price on it
  3. treadmill
    treadmill Member
  4. Drift Dango
    Drift Dango Active Member
    Bolton
    Works as a car though ?
  5. treadmill
    treadmill Member
    Yep it sure does
  6. Blackett
    Blackett No Comment
    @ Santa Pod
    Is this the one that used to come to Mallory back in the day?
  7. Robsy
    Robsy Member
    The Future
    What sorta state is the shell in? Looks clean, but then looks can be deceiving!
  8. treadmill
    treadmill Member
    No dont think it is blackett, and it pretty good bit of rust on drivers rear arch will get some more pictures
  9. DouglasB
    DouglasB Member
    Edinburgh
    Sent you a pm mate
  10. enginebuilder
    enginebuilder Active Member
    swansea
    That is well priced! And we'll built by the looks of it. Glwts
  11. Blackdamus
    Blackdamus New Member
    This wouldn't happen to still be for sale would it?
  12. DouglasB
    DouglasB Member
    Edinburgh
    It's gone and now up in Scotland with me :D
    #12 DouglasB, Aug 20, 2015
