Hi, currently in the more final stages of my s15 1jz conversion. Need advise where to get a few things. First I need a clutch line for a r154 from standard mastercylinder. Also need a throttle cable for a aftermarket plenum intake manifold. Any advise will help. Thanks
I'm not sure if either part is available off the shelf. A company like HEL can probably make up the clutch line for you if you know what the fittings / lengths are. I think they have an online custom hose maker in their shop. We usually make our own throttle cables with a universal bike brake cable and a cable end with a grub screw.
