1jz single turbo query
Thread in 'Technical Questions' started by Lukeac90, Apr 15, 2020.
  1. Lukeac90
    Lukeac90 New Member
    New Zealand
    Hey guys.
    I am going to be doing a single turbo conversion on my 1jzgte non vvti. I was looking at getting a gtX3076R but now from a turbo company they have suggested I use a HY35 obviously a much cheaper option. I am looking for that 400-450whp figure and want it to be pretty responsive for street use. I will be using all stock internals until finished thr conversion then I will be putting cams in.
    So just wondering what peoples thoughts/experiences are with the two options.
    Will the hy35 be a good option and not be to small?
    All info appreciated
    Thanks
  2. Hunts
    Hunts New Member
    Edinburgh
  3. Lukeac90
    Lukeac90 New Member
    New Zealand
  4. Nite_Shayde
    Nite_Shayde Active Member
    The Big Smoke
    You'll be happy with a HY35. If you're able to run a high quality twin scroll manifold, a good spec 11-12cm HX35 should spool very similarly while allowing for better top end and a bit more power.
  5. Lukeac90
    Lukeac90 New Member
    New Zealand
    Cheers, thanks for the response. I will be running a high quality manifold with my setup
