1uz miata swap
Thread in 'Technical Questions' started by JWW, Mar 6, 2018.
  1. JWW
    JWW New Member
    With the 1 uz miata swap, do you need to change the sump or modify the sump? also am i right in thinking the 1uz is a tiny bit beter than the 3uz with the only difference being the sleeves ? cheers
  2. mad.matt
    mad.matt Well-Known Member
    Rods
    IMG_0070.
    Sleeves
    block%20004.
    block%20005.
    Pistons
    3uz%20013.
    Fasteners
    IMG_0072.
    • Informative Informative x 1
  3. JWW
    JWW New Member
    interesting. so reliability wise would i be better off getting the 3uz im guessing they're both rebuild-able ?
  4. Minimoke
    Minimoke Member
    Every picture posted tells me the 1UZ is the superior option.
  5. mad.matt
    ^ This.
    Either way, standard or otherwise, I would personally go for the 1UZ.
    They are so ever engineered, it shouldn't give you any issues in a crisp packet like the MX5/Eunos/Miata - it pulled my LS400 to *** speeds and that was 1700kg.
    The 1UZ has higher aftermarket support, better headroom for boost (if you wanted that) and is less complicated if you're having to go and faf about with wiring.
  6. JWW
    JWW New Member
    so when installing into the mx5 will i need to modify or buy a new sump?
  7. mad.matt
