1UZFE 530D ZF Gearbox Conversion - Help Needed!
Thread in 'Technical Questions' started by Gearoid46, Feb 15, 2015.
  1. Gearoid46
    Gearoid46 Member
    Hey guys, has anyone here used the ZF 530D gearbox on their 1uzfe, if so what clutch , flywheel and pressure plate did ye use? I have heard to use a 530D gearbox , pressure plate and clutch , along with a re-drilled 3sgte MR2 flywheel but I'm not fully sure if this will work. Any help would be greatly appreciated. Thanks! :nod:
  2. -sideslide-
    -sideslide- "ent it"
    Nav at f1 moto or drift moto
  3. Gearoid46
    Gearoid46 Member
    Drift moto do custom flywheels with an E34 M5 clutch, which is fine if you have lots of $$ lol. Looking for the cheapest option available.
  4. -sideslide-
    I had a re drilled Mr2 flywheel but finding a clutch to take the power was the best part of 2k. I had a custom 2jzgte flywheel done.
    Everywhere is expensive for 1uz
  5. kam
    kam I've touched Chris Parry
    Is yours turbocharged or something?
    #5 kam, Feb 16, 2015
  6. Mitch
    Mitch In moderation
    How about an ABC-Clutch kit? Speak to Dale_B on here.
  7. -sideslide-
    yep its the torque more than the HP once you sort the cams and a quick P&P just kills the clutch and the boxes :D
    The cheapest way is to find a flywheel specialist send them your ring gear and flex plate or something with the crank holes in then tell them you want it for a what ever clutch you want its still going to be £300 odd
    just make sure you future proof it i.e. if you think you will boost Mr2 clutch might not be great. a few fair have boosted to 500hp on a stock/near stock motor.
    #7 -sideslide-, Feb 16, 2015
  8. Gearoid46
    Gearoid46 Member
    Thanks for the help man. For the moment, I'll be staying N/A , but down the line I might turbo it. Probably would be best to get the flywheel that has the cheapest uprated clutch available now, rather than down the line.
