Minty.Fresh Boosted Altezza
Thread in 'Project Cars and Builds Threads' started by Pete_the_Russian, Jul 27, 2013.
  1. Pete_the_Russian
    Hello gentlemen, and ladies of course. I have been around the forum for a while now and decided that it is time to create a build thread at last.
    I might insult the previous owner(s) of this car slightly but what the hell....here goes
    First off, i got the car back in August 2011 from London. By the looks of it the car wasn't really looked after by the owner since he changed his cars like socks. It didnt have the cam belt changed, the fitment was terrible as it was rubbing catching and making a whole ton of weird noises. The turbo was over boosting and the injectors were maxing out. So being straight out of uni, I found it really hard to sort those things out :D so first things first... I had to find a job to pay for the car :D
    Here are some pictures from when i first got it.
    The first drive, the level of happiness can not be expressed in words :D
    And some more pictures taken later that day.
    First thing that bothered me was the wheels rubbing on the arches, so the following day the car was raised a few mm until I came up with a permanent solution.
    The permanent solution involved waiting until all the tyres were worn out and replacing them with narrower tyres running a bit of stretch....I needed a job! :thumbs:
    Once that was done, the car was lowered even lower than before. This lasted for about a week, until my heart started breaking over the sound of the exhaust scraping on the ridiculous speed bumps around where i live. So up it goes again :o
    I ended up with this.
    And with some 5mm spacers on the rear
    Havent had any rubbing of the tyres and only a few scrapes here and there on the speedbumps. So winter was spent with the car in the current state as I really had no money :D
    #1 Pete_the_Russian, Jul 27, 2013
  2. Pete_the_Russian
    Feb 2012
    Then some problems started. :? The car started to run extremely rich so that caused it to fail its MOT. In to the garage it goes...perfect excuse to change all the bits I wasnt happy with. Luckily I had a job by this time ;)
    The solution was to have it remapped, I didn't want to go to a mapper empty handed, so I ordered some bigger injectors.
    Then since the car was in the garage i decided to change the clutch release bearing. So ended up in taking the exhaust off and the intake manifold to get to the gearbox.
    This once again ended up in another mission. :lol:
    The cells in the cat had a massive hole in it, from the engine running rich, so out comes the cat and in goes the decat pipe. ( didnt take pictures)
    While the intake manifold was off, it was given a good clean and made shiny :)
    During the process of changing the front ball joints i had another idea of fitting some camber bushes to the rear arms...(got pretty tired of having extreme tyre wear on the inside)
    that rusty arm is from another car that i have as a spare, so no need to say that the car is left outside to rust :lol:
    Few other bits were done, such as a welded diff.
    Kept my open diff as well incase i ever got fed up with it...doubt it i will though :)
    Next step is taking it in for a remap and finally getting it back on the road and on the track.
    The car as it currently stands
  3. Pete_the_Russian
    May 2012
    I might have forgotten to mention that the main purpose that this car was purchased was to drift and this is where I started to prep the car for the first drift day :D
    Went to B&Q, got some T-brackets and drilled them out to get the holes in the right place. Proper bodge job...but hey...it works. This was the result
    Next... the remap
    Straightaway managed to solve the injector problem i have had since February and towards the end of the session she was pushing around 264bhp at the flywheel @0.5bar.
    So at last she is driveable and all is left is a timing belt change and she will be ready for some track time.
    It felt like a completely different car now, i must admit i was even a little scared when i got in after the dyno run. The engine response and power delivery was unbelievable...what was i driving before?!? :wack:
    Before and after
    I think the actual first dyno run pushed around 190bhp :lol: the 223.1bhp figure was done after some tweaking as the car wouldnt rev past 5k :lol:
    223.1bhp was pushed with completely screwed up timing, which resulted in boost spiking up to 0.8bar with the torque curve being all over the place. The car was driven on that map by previous owner and god knows how many before him.
    Now its pushing 222.5hp at the wheels, which is....very, very, very fun to drive to....tescos:euge:
    June 2012
    So it was time to do the timing belt. I was very surprised when all the garages I asked to do the timing belt said no....(I just didnt have the time to do it) But in the end I managed to put a few hours aside. It took about 4 hours in total...3 of which involved removing and changing the water pump :lol: :lol: All i can say is that it is a pain in the arse!!!
    Never done anything this fiddly in my life!
    Got the timing bang on the first time and car goes like a dream!
    While i was on a car mission, i decided to fit the spacers i picked up from a friend.
    Initial offset
    After
    Had to raise the rear slightly as i havent rolled the rear arches yet, but so far on the worst roads it only rubs a tiny bit.
    Happy birthday to me :o Picked up a little something :D Got very fed up with having my arse cheeks on the handbrake most of the time...not my type of thing :rolleyes:
    Got a set of bride rails and managed to bolt the seat to it. Pretty happy with the result.
    #3 Pete_the_Russian, Jul 27, 2013
  4. Pete_the_Russian
    August 2012
    Finally made it to a drift day and i must say, the car pretty much drifts itself. Feels so planted and the turbo adds a nice bit of torque in the low end.
    a bit of cone munching
    It didnt stay dry all day :(
    Damage wise the car held up really well. The engine, gearbox and suspension felt solid all day....Had a little squirt of power steering fluid though. Looked like it was overheating bad. Still dripping on the drivers side when its parked up, haven't had a chance to look where exactly its coming from though.
    Anniversary present :euge: yes, I am sad
    Strut brace
    Dont need this
    Fitted the power steering cooler.
    #4 Pete_the_Russian, Jul 27, 2013
  5. Pete_the_Russian
    And then the girl was garaged for the winter until March 2013... here we go
    From the day that I fitted the bucket seat, I was constantly unhappy with the seating position. The seat was too upright. The steering wheel was too far away....
    So I decided to get it sorted.
    First off, a nice pretty OMP wheel
    The bride rails that I had before, were chopped down and fitted with some side mounts
    I nearly went down the route of mounting the seat without sliders....but couldnt bare the thought of not having the adjustability :lol:
    So this is my new home
    Next....remove these excuses for coilovers
    And, in go the HSD's
    K-Sports used to bottom out on every second bump. Not sure what the spring rates were on those. But the new 12/10 setup sounds good to me.
    HSDs are so much better....but the k sports used to go so much lower. So I am stuck with the current ride height :( But at least the handling is mediocre.
    So I went out to test the new suspension and got a little too carried away
    S14 wheel to the rescue! :wack:
    I had to occupy myself somehow.
    Like this
    Primed
    Not a performance mod, but should keep the interior nice and neat :D
    This seasons focus, is definitely suspension
    25mm RCA's. Cheers Dale ;)
    6mm rack spacers -> 3.5 turns lock to lock
    Took me a while :D , but here is the end result
    Looking a bit sorry for herself :(
    And finally ready to come out
    Lets see what Pembrey has in store for us :thumbs:
    My first cripping point :thumbs:
    Pembrey turned out to be a very nice little track. Im going to miss it
    Im sorry, I dont smoke :p
    #5 Pete_the_Russian, Jul 27, 2013
  6. Pete_the_Russian
    So as I said earlier, its all about the suspension..... I was a little bit worried about the kink in them not being as large as altezza ones. They are meant for a jzx100, but as it turned out I had no reason to worry.
    If anything it has more :D Still got a bit of clearance
    Using the stabiliser links as a guide :) , I dialed in the max amount for time being.
    Before
    After :D
    So that pretty much a short story of our relationship over the past two years....
    Currently in the works...Short steering knuckle + 30mm RCA
    #6 Pete_the_Russian, Jul 27, 2013
  7. Pete_the_Russian
    Before my move up from south wales to Aberdeen.....A few purty pictures
    #7 Pete_the_Russian, Jul 27, 2013
  8. Pete_the_Russian
    These turned up after a looooooong wait from Japan :D
    Just need to modify the hubs now so the top arm runs more parallel to the ground.
    #8 Pete_the_Russian, Jul 27, 2013
  9. Pete_the_Russian
    Locking collars fitted
    And waking up to find out that the wheel has finally shat itself
    one step forward, two steps back.
  10. Pete_the_Russian
    Hello new wheels
  11. Pete_the_Russian
  12. C1arke
    C1arke Member
    God I love that car
  13. Pete_the_Russian
    A very very quick update
    Buy boot wing
    Paint boot wing
    Ruin boot wing with fuel spray while changing pump
    Destroy backbox
    Melt cam sensor
    On the upside...the knuckles are nearly finished
  14. Jites
    Jites Active Member
    looking good peter man, your exhaust, subframe and pretty much the entire under side of your car took a beating the other night, that was scary shit, so many sparks haha!
    got the spoiler fixed yet?
  15. DtheBUK
    DtheBUK Active Member
    I can't believe you raised it. Poor show
  16. Pete_the_Russian
    Hahaha! Yeaaaaa, the subframe wasnt enjoying it.
    Gonna raise the rear slightly for this weekend, so I can actually get to the track with the full car :D
    Spoiler....havent had the time....or the money to buy paint :D maybe get around to doing it next week. Its all prepped though, just needs a few coats of paint
    - - - Updated - - -
    Oi! I havent raised it yet!
    #16 Pete_the_Russian, Aug 1, 2013
  17. twiglett
    twiglett Active Member
    My exhaust is the same.
    And I have some braces under the fuel tank that have nearly worn through.
    The sparks light up the road when there are no streetlights.
    I'm making an exhaust with no flanges apart from the downpipe and no silencer boxes so it has nothing to catch on then I'm going to bolt some steel blocks to the subframe where it rubs on rough ground. Sparky sparky.
  18. Pete_the_Russian
    Since fitting the locking collars, my subframe has dropped a few mm, so that didnt help :D And I know what you mean about braces. Some of the bolts on the small subframe braces have worn through :D
    You mean an exhaust like this?
    Got one, but it doesnt fit since my downpipe is at least 50mm further forward than stock. Got caught on a ramp when i was reversing and mangled the shit out of it.
  19. Jites
    Jites Active Member
    get wallace to sort out the downpipe dude, that new exhaust looks decent. and loud!
  20. twiglett
    You got that from Craig didn't you.
    I was going to buy that but decided against it because I can make one for about £80.
    Did you use jzx100 locking collars? As thats all I can find.
