Can you use driftworks offsetspacer with a 5mm spacer? The problem I have the offset spacer hit the rack to early. If its max i am really disapointed in my driftworks setup....
Yeah just the angle, rollcenter bit is amazing and the way the car feels over bumps etc so amazing, its the lock i am little worried about. Have a s14 with OEM LCA´s extended 26mm (s14 LCA) dw geomaster dw offsetspacer dw R33 kinked tensionrod camber -3´50minutes Toe in ´10min out caster like 7degrees and pretty normal rideheight not superlow not superhigh not near this
How much angle can you achieve? What is limiting the lock? I'd play around with the caster in your case. The S15 had nothing custom, all off the shelf.
The Offset spacer hits the rack, under 60degrees closer to 50-54degrees, nothing accurate to meassure with
