Pack Of 5 Ice Hockey Pucks - Black x 5 | eBay And some 10mm bar, washers and nuts. Shouldn't cost you more than £10 all in. Didn't like them on my S13 though. Changed back after 2 weeks.
Yeah great if you like a really solid feel but dont mind turning your car into a dildo on idle. New stock mount or up-rated rubber ones are best on a daily.
Thanks lads, wouldnt mind some viberation but is it really bad? I had the diff welded for two years in it so cant be any worse than that surely?
The reason im thinking hocky pucks is because theyre dirt cheap and new standard mounts would be a bit steep for and old diesel yoke
don't waste your money on hocky pucks if your going to do this most retarded idea ever, then you may as well just stack a load of penny washers up or drill a hole through a block of wood, be just as good lol People have an extremely lack of understand if they thing hocky pucks are better then solid mounting haha
A great cheap replacement/upgrade compared to standard engine mounts. Not sure about daily driving with them though. Had mine in about a year now and not a single problem.
Not really going to have a problem with them but they are pointless you may as well just solid mount the engine for free instead of wasting it on hockey pucks lol
I was going to solid mount my engine but it took £5 and 30 mins to sort it out with hockey pucks, I prefer doing this than shoving 50mm of metal spacers between the engine and subframe. This is the second car I've had with them and to be honest I've not noticed they've been fitted, although they are BMW 6 cylinders. B&Q do some nice long M10 bolts for £1 each, saves messing with double nutting both ends of threaded bar.
i solid mounted my m50 in my daily e36, no problems what so ever, i had a volvo 340 with solid mounts and that was terrible.
Ermm, take out engine mounts that are rubber, replace with something solid ie 'metal washers block of wood (lol!) etc.'
