Breaking R32 Gts-t Big spec HKS Turbo kit Tripple Plate Clutch Thread updated sold parts removed My number is +353857581985 Prices are open to reasonable offers, can deliver parts anywhere at buyers expense Engine turned out to be RB25 bottom end bored to 87mm and standard 71.7mm stroke which makes it 2.6. It was rebuilt with Tomei forged pistons, HKS 264 8.53 cams with adjustable pulleys, good thick metal head gasket and gtr rocker covers €1,700 Denso 550cc Injectors with rail €350 RB25 gearbox perfect €500 Cusco twin bar front strut brace €180 HKS GT3037S-52T BB Turbo Kit with everything HKS including downpipe oil lines HKS external wastegate with screamer pipe HKS 6 branch manifold 4 inch turbo intake pipe with hks air filter and brand new reload sponge €1700 o.n.o [/URL][/IMG] Adjustable fuel pressure regulator with earls braided lines €150 HKS Cat back exhaust has two very small hole in middle pipe easily welded €160 Apexi AVCR Boost controller with braided pipes SOLD HKS Fuel vein controller €120 Old skool Rev/Speed Meter €80 R32 gtr standard ecu €120 Hks F-con SOLD Gauges SOLD 18 Row Toyo Oil cooler and filter relocation kit €350 not cheap toyosport crap Greddy Intake Manifold with 100mm FQ throttle body SOLD HKS Triple plate clutch only 500 miles like new €800 Battery relocation kit for r32 ect. €50 Starter €50 Altenator €50 P/S Pump €50
What number is cast on the head and the block? On the bottom right of the block on the turbo side you'll find a flat surface with RB2* written on it, that'll tell you the block type too.
