Breaking s14 lots of standard parts available (Prices are collected from Bristol) Doors (complete with mirrors door cars etc) £30 each Rear bumper (purple slight damage) £20 Boot lid without spoiler £15 Rear poly bushed subframe £70 z32/s13 drum brake 5 stud rear hubs complete with handbrake cables £100 Fuel tank £30 4x standard wheels all with 3-4mm tread £80 2x modified front subframes ( rack brackets moved 20mm forward) £100 each S14 extended lower arms (+20mm) £80 z32 master cylinder £50 S14a front grill £15 Prop £30 Driveshafts £20 each Sr20 Gearbox £140 Sr20 Engine 93000 miles £250 (PM for details) Dash £50 Carpet £40 Rear side plastic panels £30 Roof lining £25 Speedo £15 May also have other interior trim i have missed Pm if interested Best way of contacting me is on 07595894491 i work in the day and can not really take calls so send me a text
I have someone local to me coming to look at the car in the next few days and hes interested in the hubs, if they don't sell i'll let you know
Rich I'm interested in the boot if its damson & 20mm lower extended front arms.In Spain at moment but would like a gander at the weekend.Is it up the unit?
Sorry mate boot is green, the arms are still standard on the car but i do a lot of modified arms and subframes so can modify them to whatever length you want i only put +20 because thats the most common
Okay that's cool.Are the front crossmembers done & ready? What supporting mods would I need as I'm running standard steering except spring washer spacers On the steering rack?I'd like the front ARMS modded but 10mm each side.Will shout you at the weekend.
Nothings modified yet so i can extend the arms to whatever you want, the modified subframe will prevent you from going over center allowing you to get more lock and your going to want to get your hubs modified, thats what makes the main difference you may also need to extend your steering rods
Updates* Coilovers & tension rods now sold Rear hubs are not standard s14 they are z32/s13 5 stud drum brake complete with handbrake cables £120 - ono
I haven't had time to modify the arms or subframes yet, I'll try crack on with it in the next week or so, I could also sort out postage for you
