Hello, Np Team is a drift team from Lithuania and we think that it would be interesting to share our garage projects and drift builds. These are our last season cars that had performed especially well considering the fact that they were built on a really low budget Description: E30 coupe m62b44 engine, m60b30 engine managment m50 gearbox with custom gearbox adapter and flywheel, ceramic clutch custom made 65+ degree angle kit in front, adjustable ackerman, camber, castor 4 brake calipers in the back (2 for main brakes and 2 for handbrake) Adjustable camber, toe in the back, Shortshifters, pedalboxes, handbrakes, all electricity custom made. Engine cooling in the back Total weight 980kg Power 300hp 420nm ~ Description: BMW e30 coupe S62b50 engine Ceramic clutch 65+ angle kit, adjustable camber plates Custom made handbrake, pedal box, shifter 4 brake callipers in the back Total weight 1230kg Power 350ag 460nm Manufacturing the first one: Working on the chassis weight All stock welds were rewelded to make the chassis stiffer Roll cage! making holes and mountings for everything we'll need Interior view. Lots of work with rear radiator mounting and diffusor, seat mountings all safety equipement mountings Modifying the cooling system. It was very importat to keep a good car balance, so we pushed everything back. Also it's really good not to have any damagable parts in front of the car When the radiator was placed the water pipes were led through the passangers side Painting time! Loads of work with electricity, suspension settings and engine placement... And finaly coming closer to the real view of the car! Sorry, but we don't have a lot of pictures of the other car, so I will just share some of the moment from the competitions Our teams drivers! Here's what happens when you push a bit too hard... Still the car has been repaired extremely fast and finished all the events in the season!
Thanks mates! The earlier post was about our last summer.. This year we have much more to show and tell Hope you like it. New cars for both of the drivers... The first one: BMW e46 325 with 800hp A little bit about the car... Engine: M50b25 engine block M52b28 ported head and crankshaft M54b30 rocker shaft forged pistons Holset HX38 turbo Programmable Link ecu Bosch motorsport 1700cc injectors Audi S3 ignition coils custom intake/exhaust manifolds Suspention: Xyz drift spec coilovers Np Parts made: Front and rear wishbones Custom camber/caster plates All polyurethane bushings 5cm wheel spacers in the back and 2cm in the front Body: glass fiber bonnet, boot lid, doors and mirrors carbon fiber roof Interior: Rollcage Sparco seats AiM instrument cluster Np Parts made: Short shifter Pedalbox Hydraulic handbrake Some pics of the build: Fitting everything to places. simplicity is the way to go... The second car: BMW Z3 3.0 Twin Turbo Description: N54b30 engine M50 gear box E36 rear suspension HSD monotube coilovers full polyurethane bushings set Chipped ecu Specific rollcage Np Pedalbox Np Short shifter Np hydraulic handbrake The works: fitting the rear suspension... The engine is mounted directly on the chassis GREEN!! <<< The first run This Z3 weighs 980kg and has 380hp Weight distribution is 52% in the front. Unfortunately that's it for this time... Will be back with more pics from the competitions soon ! By the way, half of the performance parts you've seen are made by ourselves. If somebody would like to ask something about them - just write a pm. Will be more than happy to help. Glad we could show our cars. Feel free to ask and comment Np Parts
That Z3 is awesome!!! Don't think there any recent threads about them :/ Good luck for the season tho :0
Thanks Mates! A small update. Finally we are out of the garage and on the track! Here's some pics: Competing against each other... five-seater Chicas And that's it for this time. Have a Nice week!
Should of kept the z3 bare shell, actually looks awesome and not like a hairdressers car Awesome builds guys!
This weekend we participated in the Eastern European Drift Championship.. Really glad that our drivers had the guts to drift at 105mph downhill in Nemunring Lithuania! By the way, the 325 e46 ended up 6th in the competition Here's some pics:
Keep drifting fun was our last weekend goal. Over 80 tyres burned during local drift training, 2 diffs overheated Also the e36 is drifted by 16 year old.
