PRICE DROP £3200 ONO . HHi have been building this car for past year and now comes the time to sell Engine spec is rebuilt with acl race bearings cosworth head gasket , can be seen only a few hours on engine since build new plugs front mount intercooler t25 tturbo tubular manifolds twin electric fans i then spent a lot of time on the shell All Subaru front end removed and fitted 200sx subframe 200sx extra lock hubs 200sx brakes japspeed track rods modified for extra lock 200sx japspeed tie rrods 200sx Bottom arms modified for extra lock tein coilovers on the rear end there is as much work all subaru rear end removed and fitted 200sx subframe 200sx 3.9 diff 200sx shafts driftworks toe arms driftworks camber arms jci magic coilovers 200sx drive shaft Other work is full subaru 22b wide arch kit fitted inside painted white aluminium fuel tank in boot external large fuel pump braided fuel lines Original dash with custom made clocks Gauges , rpm oil pressure and temp, volts, boost, water temp Custom flip switch ignition panel Hydraulic handbrake custom made carbon fibre rear bumper defused carbon fibre front bumper canards Bot in roll cage car comes on 18 inch ultralight rims aswell as space savers for transport as car is 6ft 2 wide with space savers on , to finish the car needs engine set up as larger fuel pump overpowering engine, sard fuel pressure regulator included , but runs and drives 4 wheel lining but its not bad Bolt in cage removed and weld in cage installed a little tidy up inside and out to make mint but not bad i been building the car but now want a jetski as mates have a couple that's why I selling , would swap for one , car drives and steers but needs a little to finish £3500 07872909883 live 30 mins from belfast airport and 30 mins from nearest ferry, can collect or deliver from airport or ferry . Google Image Result for http://cdn3.spong.com/pack/t/u/tunnelb17638/_-Tunnel-B1-PlayStation-_.jpg
Thanks , yeah as great potential to be a awesome driftcar but different to everyone else. , some hours work in this car
I love this car. Something really different and well priced, tried to buy it the last time it came up for sale but missed out on it! If I wasn't in the final stages of buying a house I'd be on the next ferry over. Looking forward to seeing some up to date photos, sounds like you've done a load of work to it since it was last up for sale. GLWTS
pictures are the same , ill take new ones tomorrow ,only home from holiday yesterday and not had time to refit bumpers, but ill get u ones. a lot changed under the car since i bought it almost 12 months ago , nothin to hide mate, i worked a lot on the underside of the car , just never finished it now want a ski as i finishing with drifting. lost interest , just bein honest about the thing , the car has nothin to hide ,any parts listed are there plain to see.
