After have some missfire problems with my wasted spark configuration, I've decided to make a coilpack retrofit, so I need : RB20DET : x6 coils (uprated or OEM) R32 RB20DET : coils harness Amplifier not needed. Could you make me offers ? Cheers Ben
Hi Ben. I PM'd you(your inbox is full) I have an rb20de engine loom if that helps. anyone that can shed some light on whether these are the same or not please? if you want pics then pm me your number, I'll whatsapp them to you cheers Umar
Sorry for that, Inbox empty ! Could someone tell me if coil harness his the same between RB20DET & RB20DE ?
Sorry for that, Inbox empty ! Could someone tell me if coil harness is the same between RB20DET & RB20DE ?
hi there..do you know why rb20det cas fully counter clockwise..ive try to set it to center but engine no power at all but i set it full clock-wise engine ok a bit..same as fully clockwise,same result..can u help me..what the problem..sorry my english not very good..
hi all..im hady from malaysia..can someone tell me why my cefiro a31 rb20det CAS run ok with fully counter clock wise..i try to set it to normal(center)engine very² sluggish..same as if i set it to fully clockwise..please help me how to solve it..
I have a coil loom for sale! - - - Updated - - - Maybe your timing belt has jumped a tooth or cas is faulty
