Hi guys am Hadi from Kuwait .... I have 350z with 2jz swap and i built it for drifting and its great car and has a great power .. its ready ... power and suspension The thing that i havent finished yet is the hydraulic handbrake ... i alrdy installed it ... ASD hydraulic 3/4 .750 handbrake reservior ... with dual oem brembo calipers and oem brembo brake pads.. and its not that good ... the system has no air .. no leaks .. and the handbrake is work but its very hard to pull .. i should pull to hard to slide.... i need help how i make the ebrake works without using alot strength while pulling Sorry for the mistakes in words if there is any ... english is not my language
Its the size of cyclinder making it hard to pull, fit a .625 wilwood and it will be a lot easyier to pull.
Or you could improve the lever design to create more leverage. You could make a larger e brake handle and/or change the point at where it rotates. You could also change the point where the cylinder push rod connects to the e brake handle.
Thanks man for answering .. i red in forum one time that .750 its stronger than .625 .. more stopping power but hard to pull is that right ?
