edit new stuff at bottom off list pulling all my bits from old post that i still have in one to make it easier prices have been reduced further as i really need to make some space for side projects cash on collection or bank transfer preferred but i now have opened a paypal for users who prefar this way prices do not include postage ................................... genuine oem 180sx rear bumper sold Forge 007p recirculation valve with yellow spring rated 15 -23 psi ..70 x 2 facelift bumpers one with the splitter ....15 each ? one sold one left clear facelift bumper indicators .... 20 ca pas adjustable bracket........10 ca crank sprocket.....10 x 4 sr flywheel bolts ...10 ca cast manifold....10 s14 rear seatbelts and buckles...20 S14 cast manifold.....10 S14 auto rad can be used in manual ...10 fog lights for s14 with brackets attached .....10 redtop throttle cable from 180sx .... sold ideal for rb conversion S14 recirc bov standard.......10 S14 auto tps.......5 Sr20det coil pack loom .....10 s14 rear discs .......10 s14 rear brake pipes and fittings......10 ca lifters x 16........20 cams exhaust and inlet.....45 each exhaust cam sold cas......25 rocker covers and cam covers in green .....20 ca sump.....10 ca wood ruff key.....10 fuel rail.......10 ca working injectors......sold ca alternator bracket ....10 universal net for storage in a car..... 10 t25 inlet housing..... 5 s14 front bumper ...10 ca crank needs regrind big end failer...10 x3 ca pistons and rods ...10 ca armrest cover no hinge ...10 CA18DET Oil cooler standard ...10 ca18det rear window wiper motor ...10 Fuel pressure regulator standard ....10 ca tps ...10 CA18DET Water pump...sold x 2 knock sensors ....10each CA18DET Oil pump..... 40 CA18DET Door handles no locks .....10 each s14a wiper stalk and signal stalk ...10 each CA18DET oil pressure switch....10 CA18DET Cold start valve....10 CA18DET Thermostat Housing Pipe ...10 PAS Power Assisted Steering Pump Bracket Mount x2 ....10 each Water temp sensors dash and ecu for ca18det ...10 the pair newly added s14 front bumper .
Thanks for being quick, I can't use this as it's not going on a 200sx. It's nice though none the less
