Nissan 200sx S14a SR20DET 1997 Drift daily
Thread in 'Drift cars for sale' started by LostKen, Jul 2, 2015.
  1. LostKen
    LostKen Member
    Hi, I have decided to put my beloved 1997 s14a for sale after owning it for 4 years. It is a hard decision to make as I doubt other cars would give so much fun as S bodies. But life goes on and I now want a sensible car. It was bought as a step up after my e36 and the torque and power it gives is immense. When I bought it years ago, it only had exhaust, air filter and exhaust. It is now running round 330HP @1.35 bar with HKS GTRS Turbo for safe boost as I requested to have a map for a reliable road going drift car. After many moons, many parts has been replaced as you can see from the list. By all means, it is not a mint car, this term is overly used nowadays thanks to many shit missile cars and dodgy lifestyler. I tried to keep it clean as well as use it properly. I have used it regularly for a daily and drove to and back from drift events. People in Southwest like Pembrey, zoyland, Smeatharpe would have probably see my car before or even knows how much effort I have put in to the s14a. Mileage now is around 114k and probably not that high as it has been running 4.1 ratio diff since 100k. Previous owner is 2 but I am not 100% sure as I won't be back to the country till this weekend, will confirm then.
    It has more than enough power for beginner and suitable for people in advance level. It is a really, really capable car for drifting and also a daily as well. Really hope it will go to a good home.
    I am looking for offers around £5500 for the s14a and I am looking for a S2000 if you wanna swap
    Viewing in Glastonbury, Somerset
    I know picture says thousands words, so I have uploaded a few
    That's how it looks now with the Cosmis wheels
    ENGINE/POWER
    SR20DET@ 114k miles
    Apex Air filter
    Decat with flanges cut off for ground clearance
    Exhaust
    Oil cooler kit and relocation kit
    Toyo Aluminium Alloy Radiator
    Apexi Front mount intercooler
    Cosworth metal headgasket, ARP studs
    Engine rebuild, skimmed, balanced @ 102k
    Castrol 10w60 engine oil, Oil and filter changed every 3k miles
    HKS GT-RS Turbo with HKS actuator (equalvaent to GT2871r 0.64)
    Braided oil and water lines
    Denso 550 cc injectors
    Z32 Air Flow meter
    Gizmo Boost controller - MS-IBC V3
    Nistune custom remap ecu with 1.35 bar
    Colder NGK spark plugs (2 grades colder)
    Adjustable Fuel pressure regulator
    Aftermarket Turbo Elbow
    Stock manifold due to aftermarket ones are easy to crack
    Engine damper
    Basically every exhaust, turbo, manifold gaskets have been replaced over the years
    ACT clutch and flywheel kit
    Walbro fuel pump
    SUSPENSION/GEO
    Welded 4.083 diff from auto Stagea
    Front and Rear strut brace
    Toyo Coilovers Front 8kg Rear 6 kg
    Adjustable top mount camber plate
    25mm Front wheel spacers
    Rack spacers
    Front adjustable tie rod
    Front adjustable castor arms
    Front adjustable lower arms
    Extended steering arm
    Modified knuckles
    Front subframe and rack move forward 20mm
    Lock stop grinded to give maximum lock
    R33 front brake R33 rear brake conversion
    Drilled and grooved front and rear disc
    Locking collars
    Polybushed rear knuckle
    Rear adjustable toe arms
    Rear adjustable camber arms
    Driftworks hydraulic handbrake with Wilwood cylinder in OEM position
    OEM mechanical handbrake moved to left for Road legal MOT and parking
    GEO set up with 4 degree in the front with toe out and 0.5 degree in the rear with toe in
    Interior
    Bride bucket seat
    Geniune Nardi Steering wheel 350mm with horn and Boss
    Takata 4 point Harness
    Oil pressure,oil temp, water temp, with warnings - all set up to warm myself not to drift/rev it until engine is warmed up
    Blitz mirror boost gauges
    Pioneer Double din player from Japanese import
    Bosozoku grab handle
    ZILLA gear knob
    Apex Rear roll-cage
    Headlining is retained to have a comfy street car
    Checkered Mat in black and grey
    Rear interior taken out but still here if buyer want to put back in
    Air con removed
    Exterior
    Many stickers
    HID kit 6000k
    Clear corner lights, clear wing indicator
    TRS Tow strap
    Kouki front bumper
    Kouki indicator lights
    Kouki badge
    Kouki rear bumper
    Kouki spats
    Dmax Carbon fibre roof spoiler
    LED rear s14a lights (black background)
    Arches rolled but not flared
    18 x 9.5 et10 cosmis wheels XT-006R all round in hyper black
    Wiring loom is relocated above the arches and plate have been put in place to prevent the wheel rubbing them
    I still have the Dmax front bumper if you want it, but it is smashed and battered as I used it for drifitng
    If you want any more info/pics or have any questions, just give me a pm, will answer as soon as possible but bear with me as I am not in the country till this weekend
    Thanks
    Ken
    #1 LostKen, Jul 2, 2015
  2. wallace.jonny
    wallace.jonny New Member
    Would you be interested in a swap for an extremely clean e30?
  3. LostKen
    LostKen Member
    Not really interested in e30 atm, thanks for the offer
  4. wallace.jonny
    No worries dude, good luck with the sale!
  5. LostKen
    LostKen Member
    Previous owner is 2
  6. karllibbo
    karllibbo Member
    Nice sensible tastefully modified corsa vxr by any chance haha
  7. LostKen
    LostKen Member
    LoL, bought a s2000 now so after cash. Offers welcome, all I can say is no :)
  8. LostKen
    LostKen Member
    Bump for 330hp of awesome fun :)
  9. karllibbo
    karllibbo Member
    I'd buy this tomorrow if my car sold asap
  10. ianlea73
    ianlea73 Well-Known Member
    When you sell you can buy my ps13 mate.
  11. LostKen
    LostKen Member
    Any offers are welcome
  12. karllibbo
    karllibbo Member
    Still got this
  13. joshpillinger1
    joshpillinger1 New Member
    What's your number mate? Interested.
    Cheers
  14. LostKen
    LostKen Member
    Sold last week, thanks for all the interest
