Wanted Help on injectors
Thread in 'Parts for sale' started by James Rwell, Sep 20, 2015.
  1. James Rwell
    James Rwell New Member
    Hi everyone.
    Im looking at getting bigger injectors for my r32 gtst rb20det. Was wondering if you can point me in the right direction. As been looking but can't seem to make my mind up. Ideally looking for a .....
    Plug and Play set up
    . Just wondering what you guys run or would recommend.
    Thanks.
    #1 James Rwell, Sep 20, 2015
  2. crazyae86
    crazyae86 Well-Known Member
    hey james wellcome here in dw
    if i am correct ur from r32 is 370cc is the same with s14 ( s15 is 480cc )
  3. James Rwell
    Thanks. Would the s15 be a direct replacement tho.??
    As im looking for bigger one but still to be a direct fit. Was think 550cc but would that be over kill.? . Should have mentioned car his a td06 turbo on it but not got right size injectors and going to put a nistune ecuon it. And I'm after about 350 hp. As still on stock block.
  4. crazyae86
    no its the same size but bigger cc u know
  5. Pilkboid
    Pilkboid Member
    rb20 injector cc is more like 270 I beleve? Gtr injectors wil go in but need a resistor pack wired in.
  6. James Rwell
    Cheers guys. I'm new the skyline ownership so all help is welcome.
    So gtr could be one way. I've seen some deatschwerks injectors that are actually for sale on dw shop says there direct fit. !?!? Would they need/use a resistor pack. And has anyone every used these injectors???
  7. Chunky899
    Chunky899 Member
    Such a small injector on a turbo motor? Are you sure about that. That's stock almera gti SR20DE injector size....370cc's sounds more like it.
  8. Pilkboid
    Pilkboid Member
    Yeah its crazy but they are. Infact i think they are actually 270. Rb 25 is 370 same as sr20.
  9. Pilkboid
    Pilkboid Member
    And rb26 is 444cc
