I'm selling my E38 so these are up for sale. BC Racing BR type coilovers. They are not the standard BR type kit that I purchased for £769 originally, they go much lower thanks to the shorter damper bodies that I purchased for £400 extra after buying the standard kit. The standard kit on mine, and many others does not lower the E38 to a level you would expect from coilovers, so I purchased the dampers to get the level you see in the pictures. It will go lower still on the rear damper bodies and lower on the front if you take a bit of preload off the spring. However you may find your sat on the Tarmac if you go lower. They also go higher if you so desire. They have only been on for about 1500mls if that. They are in excellent condition with no corrosion on the damper bodies and the locking collars are all free. They include, Front coilovers- with extra low damper bodies and camber top mounts, Rear coilovers- with extra low damper bodies and bush type top mounts, Front Damping adjusters, Rear damping adjusters and the additional damper extenders (£25 option) Front short drop links, Allen keys and C spanners £600 Ono Cash on collection preferred. If they fit an E39, I might keep them!
