Hi, I sell a conceptua turbo, A stage5 brand new,Never used For rb25det 430-450 HP 360 degree thrust bearing Compressor Wheel Inducer 57.15mm Exducer 76mm Compressor A/R .70 Turbine Wheel Inducer 60mm Exducer 55mm Latest Backward Curved Blades Turbine A/R .63 Replace the oem turBo, oem elbow can fit. Come with all hardware for fitting 515 gbp posted Brand new 3" one piece elbow downpipe stainless Steel, fit r33 gtst oem turbo , 130 gbp posted 600 gbp all parts together posted Thanks
Je viens juste de tomber sur ca: "Stage 4a and Stage 5 must be fitted in conjunction with a stainless lowmount manifold to get the clearance necessary for the large compressor housings " Je vais le laisser mais merci pour les reponses
Not strictly true. You can fit it with a spacer (basically just a T3 flange) with gaskets in between obviously. Same turbo I've got.
Ah right I see! Does the elbow need modifying at all once the spacers are fitted? How about the oil feed and return lines? And what power figures are you running?
My elbow fits fine but mine is in an S14 with custom downpipe and flexi, custom exhaust. It was all made up on the car. I don't think it would cause any problems though. I fitted braided oil and water lines, same fitment as the standard turbo. Have only got mine running in the unit, nowhere near mapping yet cos I'm still building the car. I'm expecting 450bhp though with all supporting mods.
