The time has come to sell my S15. Imported by me in 2011 so I've had it a few years now , it's not the usual fresh off the boat rubbish! This car was viewed in Japan (rather than someone bidding based on a tiny thumbnail picture). It had quite a lot of work done to it already but I've changed/replaced/upgraded most of it over the years with some help from Garage-D along the way. At this point I'll say they probably know the car as well as I do and I'm sure they'll be happy to give an impartial opinion and answer and SENSIBLE questions (please don't waste their time though!). Bodywork: The bodywork is in good condition. A girl in a 206 ran into the back of the car at about 5mph. Not much damage but the rear bumper was rebuilt (as I couldn't find an aftermarket one in the UK that I was happy with the fit). It was jigged up anyway to double check everything was straight. There was some rust in the sill area so I had that ALL professionally cut out and new metal welded in. The car was then painted to a good standard. However, this car is for going, not for showing so if you're looking for a trailer queen it will take about £4-500 to get it there. Modifications: Uras kit (Genuine) LSD HSD coilovers less than a 1000 miles ago Z32 MAF New, less than 1000 miles ago Splitfire leads Garage-D/Quaife 'box ARC clutch K-sport big brake kit Apexi Power FC and commander Walbro pump Gizmo boost controller Apexi turbo timer Full exhaust including new downpipe Induction kit Super Made Ganador carbon fibre, electric door mirrors etc, etc...probably a LOAD of stuff I've missed. The car pulls really well. It was set up on the dyno by Garage-D. I can't remember what power it made but everyone commented that it pulls like it's got much more. If you care about that sort of thing I'll try and get a copy of the graph, I think it was around 350hp. The car just isn't getting used and it seems like a waste for it to be sat there so I like it to go to someone who's going to get some use out of it. If you don't hand over the cash or I don't like the look of you, you won't be taking it for a test drive so don't waste anyones time. Having said that, if you're serious, you're welcome to come and take a look. I'm looking for £9750 or offers around that price. PRICE DROP. NOW £9000! That includes the S15 FKU plate (which people seem to really like). I also have the following cars that I could be persuaded to let go of... 350Z allegedly used in the filming of Fast and Furious: Tokyo Drift - Full Veilside V3 kit, etc. Needs some interior and paint. £12,000 W211 E55 AMG tuned buy MKB (650hp+, 212mph) Silver, top spec, KW coilovers, etc, etc 60k genuine miles. £15,000 R32 GTS with R33 GTST engine, full cage, Power FC, £20,000+ in mods. £9,000
How is that build thread meant to help sell the skyline? It's confusing as fuck to read.... Stop being lazy and put up a spec and pics if you want to sell the car.
For those too lazy to read or too thick to understand the build thread... **Modifications Include the Following - Nb. PC stands for Powder Coated In Textured black. *Engine - R33 GTST SERIES 2 RB25DET and Gearbox Blitz SUS Filter Custom Air feed 100mm Custom Intake pipework 80mm PC Custom Greddy Racing Re-Circ valve PC Custom Intercooler pipework 80mm PC Custom Re-Circ Valve pipework 50mm Custom Fitted Greddy TD06-20g Turbo Custom Heat Shielding HKS Cast Iron Manifold HKS External Wastgate Matched Exhaust Ports Nismo N1 Intercooler Custom Throttle side pipe 90mm Q45 throttle body Ported, Polished and Matched Greddy Revised Intake Plenum, Custom Red Sparkle RB26DETT Rocker Covers, Custom Fit, Custom Red Sparkle Tomei Poncams Tomei Headgasket Tomei Pistons Lightened, Polished and Balanced Crank *Fuelling - Pacet Lift Pump Bosch 044 Main pump Custom Swirl Pot Trust Swanky Rubber Hose Triple Filtered system Nismo Injectors Nismo Fuel Pressure Regulator S2 fuel rail Powdercoated with Polished caps *Cooling and Additional Equipment - Nismo Twin core Copper Radiator Greddy Radiator Cap Greddy Oil Cap Greddy Oil catch Tank PC Greddy Anti Bubble Tank PC Greddy Oil Filter Relocation kit Greddy 21 Row andodised Oil cooler Goodridge braided oil lines Goodridge High Temp Line covers Goodridge High Temp Heat Sheilding Driftworks Power Steering Cooler Custom Alloy Overflow Tank Custom Alloy Washer Bottle Tank (in boot) *Drivechain and Footwork - ORC Twin Plate Clutch ATS LSD - 4.1:1 Ratio NISMO Engine Mounts DRIFTWORKS Complete Bush Set (Every single Bushing) DRIFTWORKS Gearbox Mount DRIFTWORKS / Nismo Steering Rack Mounts DRIFTWORKS Steering Colum Metal Bush DRIFTWORKS Front and Rear Lower Arms DRIFTWORKS Front Tension Rods DRIFTWORKS Front Upper Camber Arms DRIFTWORKS Rear Camber Arms DRIFTWORKS Traction Links DRIFTWORKS Toe arms TEIN Steeing Rods and Ends HKS Hiper D suspension (awesometown) Two Tuners Complete Roll Cage and Chassis Seam Welding. *Bodywork - Geoff Moores Complete Re-spray in Ltd Sparkling Silver (R34 Z-Tune) (Glass Removed) D-max Wide rear Panels Aero Palace Vented Front Wings Uras Complete Type 2 Kit GTR N1 Bonnet GTR Bootlid Custom 6ft1 Wide Feedsports Wing Custom Wing Mounts Custom Diffuser set Custom Cannard set Custom Wing plates Stainless Steel Bonnet and Bootlid Pins *Wheels and Brakes - 18" Eurolines Z32 Brakes Uras Drum Shoes Modified Drums ... Braided Lines *Interior a safety Features - Cobra seat Drivers Side Bride Super Low Mount Subframe Custom Flocked Dash, Centre Console and Door cards High Impact Roll Cage padding over entire front cage Heater controls re-located into centre consolole ECU relocated to glovebox Nardi Torino Classic 330mm Wheel WITH centre ring!!! Custom made Mitto Gearknob K's Factory Handbrake button Custom made Handbrake and Gearlever Gaiters Sparco 6 Nozzle FIA Approved Fire System *Electronic Items - Apexi Power FC ECU Blitz SBC ID Boost Controller Attain Engine Temp Controller Custom made Fuse box for After Market items Defi Link Control Defi Link Display Defi 80mm Tacho + Warning Light Defi 60mm BF Boost Defi 60mm BF Exhaust Temp Defi 60mm BF Fuel Pressure Defi 60mm BF Oil Pressure Defi 60mm BF Oil Temp Defi 60mm BF Water Temp Defi Additional Meter hoods X2 Defi Additional Warning light
Wasn't looking for px but your car is the EXACT spec I'd want so we could possibly work something out with the S15 or the merc.
Hi bud, bmw is an absolutely epic daily. Effortless to drive. My number is 07833461051, could you drop me a message on whatsapp or something for a chat? Regards
Interested in this? It has got different wheels on now http://www.driftworks.com/forum/drift-cars-sale/243468-skyline-r33-gtst-spec-2-pure-grey.html
