IS200 2JZ-GE build
Thread in 'Project Cars and Builds Threads' started by Seddon11, Apr 12, 2016.
  1. Seddon11
    Seddon11 New Member
    So my friend was scrapping his is200 the other day due to a blown engine, so i threw him £200 and he chucked in a draper spanner set along with some draper screwdrivers. i borrowed a tow rope and dragged the is home with the golf(really lucky as the carabena snapped as i pulled up outside the house), with a little persuasion we pushed it onto the drive. after some research and restricted funds (student life) i decided a 2j from a gs300 would be the engine for me, just got to put some hours in at work and then the parts can start rolling in, heres the car as it sits[​IMG]
    #1 Seddon11, Apr 12, 2016
  2. Seddon11
    Seddon11 New Member
    First part bought for the lex, picked it up whilst i was getting some ramps to get the golf on the drive cause i may have lowered it a little too much, not bad for £15[​IMG]
  3. Seddon11
    Seddon11 New Member
    also been looking, which is the best way to mount the engine?
  4. Minimoke
    Minimoke Member
    They left the factory with the 2J-GE as an IS300, so I'd imagine it's either a straight drop in job or something very simple if not.
  5. Pete_the_Russian
    1. Take engine from gs300 with engine brackets and mounts.
    2. Stare at it for 2 minutes.
    3. Spend another 5 minutes dropping the engine into the engine bay.
    4. Now you have a JZ in your IS
  6. Minimoke
    Minimoke Member
    Hmm. Sounds a bit too complicated for me.
  7. Gooly
    Gooly Member
    What you doin for gearbox?
  8. Aidan_G
    Aidan_G Member
    get any old gearbox from an e36 probably cost £50-100 and a bmw gearbox to jz adapter plate for about £250. cheapest option really. can always get a box from a 530d e39 if you plan to boost it. loads of lads running 1jz's and 2jz's use them
  9. Al_E11evens
    Al_E11evens Member
    Worth trying an adapter on the lex gearbox too mate. One of my pals just swapped in a 1uz and used his 6spd is200 gearbox ;)
  10. Seddon11
    Seddon11 New Member
    im studying mechanical engineering at LJMU so i have access to solidworks + 5 axis CNC milling machine, so im going to fabricate my own bellhousing save some pennies :o
  11. Seddon11
    Seddon11 New Member
    Which ECU should i use? ive got a mate with a megasquirt? will that do?
  12. Al_E11evens
    Al_E11evens Member
    If you're putting in a vvti you will need the MS3 for that to work bud
