its a 1999 holden hsv commodore bought it a while ago with the idea of using the running gear for something different haven got near it so thought id through it up an see how it goes . the cat is cat c has a broken front screen an needs the sills an chassis leg welded also has some dents here an there would suit as a track car or the perfect conversion for someone looking some v8 power the car runs 100% both engine an gearbox are all good . the engine check light is on when the car starts as its looking for an air flow meter as with the super charger it now uses a map sensor .i done a diagnostic on it an its the only fault on the ecu but as i said it runs 100%. cars as follows pics an video taken today ls1 supercharged 6 speed gearbox (t56) lsd peders quick shifter lowering springs may part x transit pickup/chassis cab or something rwd jap £4995 call me on 07835897435 walk round video
Fucksake brian you always have lethal stuff about ye! What you rollin about in now? Still regret sellin that purple 180 kouki i got from you
