Hi All I have a M50B25 non-vanos engine and I want to stroke it out to a 2.8l Specs: M50 84mm Iron Block M52b28 Crank M52b28 Rods M54b30 Pistons - to lower the comp MLS .140 Gasket ARP Head Kit Holset HX35 Turbo I plan on running about 10psi of boost and I want to use bosch 0-280-150-431 from a 9000 Saab Turbo They are the Red top injectors and are rated at 34.15 LBS/HR @ 3bar or 360cc/min @ 3bar Will this setup work or do I need bigger injectors ? Thanks
