Breaking Whole Car, Parts and prices below. [TABLE="width: 923"] [TR] [TD]Front Bumper[/TD] [TD]£50.00[/TD] [TD]Fibreglass (Not sure of Brand) with Rubber Skirt. Average condition[/TD] [/TR] [TR] [TD]Front Wings[/TD] [TD]£50.00[/TD] [TD]Vented +25mm[/TD] [/TR] [TR] [TD]boot with spoiler[/TD] [TD]£50.00[/TD] [TD]boot with rocket bunny style spoiler.[/TD] [/TR] [TR] [TD]tail lights[/TD] [TD]£50.00[/TD] [TD]14a tail lights, good condition, no cracks. Comes with centre bar.[/TD] [/TR] [TR] [TD]headlights[/TD] [TD]£100.00[/TD] [TD]No cracks, good condition, clean with HID kit. Side lights have a small crack in but look fine.[/TD] [/TR] [TR] [TD]bonnet[/TD] [TD]£50.00[/TD] [TD]Blue, some rust along the front edge, surface only. Come with bonnet pins and latches.[/TD] [/TR] [TR] [TD]doors pair[/TD] [TD]£100.00[/TD] [TD]Blue, no rust, come with glass and half door cards cut for a roll cage.[/TD] [/TR] [TR] [TD]leather seats[/TD] [TD]£40.00[/TD] [TD]Standard cream leather seats[/TD] [/TR] [TR] [TD]bucket seats[/TD] [TD]£250.00[/TD] [TD]Bride fixed back Reps. Good condition, no tears, wear or stains.[/TD] [/TR] [TR] [TD]Sparco 4 point harnesses[/TD] [TD]£40.00[/TD] [TD]In date and good condition.[/TD] [/TR] [TR] [TD]Gauges[/TD] [TD]£40.00[/TD] [TD]£10 Per Gauge with senders. Oil Pressure, Oil Temp, Boostx2[/TD] [/TR] [TR] [TD]hydro handbrake[/TD] [TD]£30.00[/TD] [TD]Generic hydro with fittings.[/TD] [/TR] [TR] [TD]Ksport brakes[/TD] [TD]£600.00[/TD] [TD]356mm disks, 8 piston callipers, brackets for s14 hubs, Ferodo DS2500 pads and braided lines.[/TD] [/TR] [TR] [TD]Brake Master Cylinder[/TD] [TD]£50.00[/TD] [TD]Pedal, Booster and non ABS master cylinder[/TD] [/TR] [TR] [TD]rear brakes[/TD] [TD]£50.00[/TD] [TD]Brand new EBC yellow stuff pads and brembo disks. Includes braded lines.[/TD] [/TR] [TR] [TD]diff welded[/TD] [TD]£50.00[/TD] [TD]Welded manual diff. ABS casing.[/TD] [/TR] [TR] [TD]Diff auto LSD with new cooler and pump[/TD] [TD]£100.00[/TD] [TD]Locks up well. ABS casing. New cooler, pump and lines.[/TD] [/TR] [TR] [TD]Diff manual LSD[/TD] [TD]£50.00[/TD] [TD]Locks up okay but not the best. ABS casing.[/TD] [/TR] [TR] [TD]Manual ABS prop shaft[/TD] [TD]£40.00[/TD] [TD]Good condition[/TD] [/TR] [TR] [TD]rear subframe with diftworks arms[/TD] [TD]£175.00[/TD] [TD]Powder coated rear subframe, solid bushes and solid diff buses, Driftworks arms and hubs[/TD] [/TR] [TR] [TD]front subframe with arms[/TD] [TD]£50.00[/TD] [TD]Front subframe, with polybushed arms, new ball joints and hubs[/TD] [/TR] [TR] [TD]Engine[/TD] [TD]£800.00[/TD] [TD]With ancillaries loom and ECU.[/TD] [/TR] [TR] [TD]Gearbox[/TD] [TD]£100.00[/TD] [TD]NO crunches or wines[/TD] [/TR] [TR] [TD]Clutch and Flywheel[/TD] [TD]£100.00[/TD] [TD]Excedy Organic clutch and driftworks lightweight flywheel. Covered 2000 miles max.[/TD] [/TR] [TR] [TD]Clutch pedal, master cylinder and slave.[/TD] [TD]£50.00[/TD] [TD]includes lines. No leaks.[/TD] [/TR] [TR] [TD]Apexi AVCR Boost Controller[/TD] [TD]£150.00[/TD] [TD]Controller solenoid pipes and wiring[/TD] [/TR] [TR] [TD]Turbo, manifold and lines[/TD] [TD]£250.00[/TD] [TD]Doesn't blow smoke, new gaskets, japspeed manifold with no cracks and braided lines. Includes Elbow off the turbo.[/TD] [/TR] [TR] [TD]Downpipe and exhaust[/TD] [TD]£75.00[/TD] [TD]Big old fart cannon and downpipe.[/TD] [/TR] [TR] [TD]Alloy rad [/TD] [TD]£50.00[/TD] [TD] [/TD] [/TR] [TR] [TD]Oil Filter relocation and external Radiator[/TD] [TD]£80.00[/TD] [TD]Lines, radiator and block adapter[/TD] [/TR] [TR] [TD]Front Mount Intercooler[/TD] [TD]£80.00[/TD] [TD]Intercooler, Pipes and Joints.[/TD] [/TR] [TR] [TD]MAF[/TD] [TD]£30.00[/TD] [TD]Works fine no issues.[/TD] [/TR] [TR] [TD]Steering rack[/TD] [TD]£50.00[/TD] [TD]No leaks or noises[/TD] [/TR] [TR] [TD]Front ARB[/TD] [TD]£20.00[/TD] [TD] [/TD] [/TR] [TR] [TD]Rear RB[/TD] [TD]£15.00[/TD] [TD] [/TD] [/TR] [TR] [TD]wheels[/TD] [TD]£600.00[/TD] [TD]Rota RKR 17" F: 8.5 et -10, R: 9.5 et -20. F: 225/40/17 Nankang NS2R decent tread, R: need replacing [/TD] [/TR] [TR] [TD]shell with 6 point roll cage[/TD] [TD]£1,500.00[/TD] [TD]Custom cages 6 point cage with door bars, welded in by Nickson Motorsport. Shell is as rust free an S14 can be. Comes with rear overfenders, tubbed rear arches and sideskirts.[/TD] [/TR] [TR] [TD]Drift wheel [/TD] [TD]£40.00[/TD] [TD]With boss, quick release and horn button.[/TD] [/TR] [/TABLE] Text or call for pictures or details 07727236311
Hello mate! I am interested in several pieces, send me an email , or mobile prefix tell me to speak for whatsapp. Thanks
Hi interested in the clutch and flywheel, clutch pedal, master cylinder and slave and the AVCR controller. Also need the brake pedal. Where are you from mate?? Would like to collect but if to far away may need to arrange sending. Cheers mate. Sent from my iPhone using Tapatalk
I'm interested in the whole front , the complete engine ( gearbox , clutch, turbo ... ) and taillights , I'll take it ya.mandame an email and talk. 190dhs1990@gmail.com
I will take the front and rear subframe and collect asap, PM me your number or call/text me on 07568343405
i would need the manual VLSD. here is my email than we can do the details. shiftyschiffrer@gmail.com cheers
