Got my s14 in the road now and it has coilovers with adjustable topmounts set to max neg camber yet the passages side give zero camber and the drivers around 3deg. What's up with this I'm boggled
Only picture I have but set same on both sides and set to max - - - Updated - - - Also this is the side that has zero camber
I have none at all tho not even a tiny bit. Think I'll oval the top hole on the coilover that mounts to the hub so I can push it back to gain some
Id be looking into the front lower front arms make sure there all straight and true. If there adjustable this might be the cause only other thing i can think of is has it took a bump and bent a mounting point or anything ?
