Will be adding more over the next few days, if your interested in stuff PM me, do not leave messages on here asking about stuff, USE PRIVATE MESSAGES! Suspension / Brakes Front extended LCA's 20mm - extended and reinforced - new balljoints (choice of s13 or s14) - £120 exchange Relocated rack S13/14/15 subframe - rack moved 20mm forward - £100 exchange Driftworks solid subframe bushes for s-body - £40 Driftworks tension rod braces (go between tension rod bolt and subframe bolt) - £40 S13 rear calipers and disks (drilled for 4/5 stud) - £50 S15/14 rear subframe - clean as fuck - removed from mint S15 (takes r200 diffs) - £75 Engine and Drivetrain RB25 into S13 exhaust, modified to be as close to body as possible, its single piece downpipe back, single box system - £100 RB26DETT cam covers - small bit of paint damage but very clean other than that - £400 RB25DET stock inlet w/ injectors - £50 RB25DET stock inlet w/o injectors - £30 R32 4.3 - has a bit of backlash but not too bad - £120 R33 4.1 (need to double check ratio) GTST diff 5x1 output - £200 R33 5x1 bolt shafts pair - £120 Nismo 2way LSD, out of case, great diff needs putting in a case - £450 SR20DET straight cam in bits, mild knock hence strip, polish/regrind crank and its good to go, has inlet, no other ancilleries - £500 SR20DET straightcam CAS - £50 RB25DET CAS - £50 RB25DET stock exhaust manifold £60 Spec 2 coilpacks - £40 Spec 1 coilpacks - £40 Spec 1 MAF - £40 Hardrace SR20 engine mounts - £100 posted Electronics - Greddy profec B boost controller - £160 posted Power FC D-Jetro (mafless) - straightcam SR - £650 posted Splitfire coilpacks - £250 posted Apexi SAFC black edition - good working order, small bit of paint missing on front face - £120 Apexi AVCR black edition - missing boost solonoid but other wiring there - £120 Interior Bride leather fixed back - worn and sun faded, believed to be genuine - £200 Recaro recliner - very good condition, basemount £400 volts black tint stepper gauge £30 S15 Steering wheel boss - HKB - £40 posted NRG steering quick release - £30 posted Genuine nardi deep corn wheel - very good condition - £150 posted Defi gauges - oil press, oil temp, water temp, boost and control box - £500 Bodywork Roof/hatch spoiler S13 - £80 S13 Supermade front bumper - repaired but good condition - £120 S13 Supermade front bumper - repaired but good condition - £120 S13 doors - swages removed, clean doors - £40 each s13 mirrors - £20ea S15 fibreglass vented bonnet - £200 Can get pictures on request when my pc isnt being a spastic.
Yeah, it goes back and forth lovely. But im guessing your actually asking my best price, make an offer, VIA PM. If you read the first line of the post again, private message me.
All the wire are include with the boost controller Apexi AVCR ? PM me mate for more information/pictures please
Hi mate my phone won't let me pm you. I'm interested in a corbeau revolution if you could pm me some pics
Message me on www.facebook.com/freddie.sharvell (will see it if friends or not, so no need to add) as if you have less than 50 posts on this forum you cant send or receive PM's
If you want pictures PM me your number so I can whatsapp them over. Same for anyone, if you want pictures of stuff PM me numbers or message me on facebook. Will hopefully be getting some time to strip the car down further later this week, but things have been a bit hectic lately so apologies for not being able to get detailed photos of every part imaginable.
