Shell Been completely stripped all sound det has been removed all unused brakets and rear seat points have been cut out Full multi point weld in fabricage cage been tig welded in Rear boot floor been cut out and braced Front bumper bar Plumed in lifeline fire eater Hand held fire extinguisher Drivers and passengers alloy feet rests Battery in boot New front screen not to long ago Body Standard 14a kit front spliter half is missing +30rear over fenders Fiberglass front arches Rocket bunny rear spoiler Skinned bonnet with bonnet vent Carbon Mirror covers Paint is in overall good nick bare in mind it's not a show car was built to be used few marks Engine Sr20det bent cam Wisco pistons Hks step 1 cams Hks rocker stoppers Cosworth 1.2mm gasket Baffled big wing sump Splitfire coils Z32 maf Large k&n filter New oil pump roaters New Acl race main and big end bearings Engine was originally built by Mike Marshall at mnm engineering and has since been down to Mike agen in October for a std balanced non ground crank new oil pump roaters and new Acl race main and big end bearings, Engine was ran in and then for mapping in November at performance hq since dun 2 events engine was leak down tested at mapping and made 323whp and 328ftlb at 1 bar and 263whp and 274ftlb at 0.7 bar so around 400/400 at 1bar Has ever so slight vvt rattle nothing that has bothered me the time I have ran it I do have another vvt sprocket I can supply I purchased as a ment to be non good item, Turbo Borgworner efr 6758 on a custom 3mm wall s/s top mount manifold custom 3" down pipe for s14, this set up made 279whp at 0.7 bar and 323whp at 1 bar there is zero play on the shaft it still like new, turbo blanket as well Exhaust Custom 3" turbo back to a rear box all tiged and pie cuts not overly loud 96db if I remember Fuelling New Walbro 340 at mapping in November New alloy hard line under car and hoses to tank and to rail New d1 fpr with gauge New nismo 740cc injectors in November at mapping Gearbox Hks 6 speed dog box dogleg, oil catch can in engine bay, competition clutch strange 4 I think it was white bunny kit, gearbox was bought from Paul at jdm gargae was removed from his personal onevia, bought in September 16 and only dun 2 events due to engine being out of car, Suspension/geometry Hsd monopros front and rear Wisefab front end recent new top mounts driftworks rear 3 arm kit Extended studs on front hubs Brakes Abs deleted Skyline r33 front calipers on a 303mm grooved big disc set up with calipers adopters with project mu pads Z32 rear calipers vented calipers with project mu pads Carbon fiber handbrake set up on a willwood .625 cylinder works really well Brake bis valve Custom front breaded lines from speed flow Rear breaded lines Diff 4.1 2way kazz diff with new kazz diff oil last event with spare to go with car Skyline 5bolt shafts Cooling Large 3row alloy rad with 2 eclectic fans Oil cooler and power steering cooler with spal fan Front mount intercooler Seats/harness/wheel drivers seat is Kevlar corbeau revaluation good condition on bride rail Passenger is a bride low max on custom rail Harness are 3" race quip camo quick lock brand new Outlaw suede wheel on a d1 snap off boss Gauges/electrics Hks oil press Hks water temp Hks boost gauge Digi oil temp gauge Innovate lc2 wideband with new o2 sensor All dash gauges works as normal Greddy boost controller hi and low boost Hard wired fuel pump relay Led tail lights Wheels skyline r32gtr wheels on front new 225/45/17 toyo t1r rota torques on rear 17x9.5 on new 235/45/17 good years eagle f1 4 rota gtrd 18x9.5 all on good skid tyres spares Fiberglass vented front wings Fiberglass skirts 4 rota 18x9.5 gtrd on tyres Std Sr 5spd box Steering rack 2 New wisefab tie rods 2 wisefab top mounts Wisefab acemen kit Various rose joint ends for wisefab kit Kazz diff oil 5l Millers cfs Various other parts Mot till ....ill have find out Location Car is located in Fraserburgh just north of Aberdeen I can deliver it anywhere at cost Price 10k firm Serous enquirers only I will consider braking if I get enuf interest on engine box turbo shell Email me at g7gno@hotmail.com or call or txt 07707181568 I will get photos to follow over next few days Sent from my iPad using Tapatalk
Car will be broken for parts, parts list will be in parts for sale next week Sent from my iPad using Tapatalk
