sr20 alternator £80 delivered anywhere in the uk {} sr20 pas pump £80 delivered anywhere in the uk {} sr20 starter £50 delivered anywhere in the uk {} 2jz ge machined block, ideal for those with a 1jz wanting more power? or even an na-t build has had the machine work done to allow fitment of oil squirters and twin turbo oil feeds, oil path ways correctly opened up so now when sat next to a gte block it's identical this is a cheap alternative to someone not willing to pay the price of a gte engine the engine comes with the original crank in great condition, the main caps and i'll throw in the rods and pistons although I'd recommend forged rods and pistons for this it's a vvti block also (can be used on non vvt head just need a bolt to block vvt oil port) £750 and postage would have to be worked out as it'll need a pallet due to weight {} {} 325td zf bmw gearbox 5 speed £70 delivered within the uk {} {} {} {} {} {} {} {}
i'll get some updated pics of the gearbox lads and i'll also take a vid of the input shaft to show if there is any play etc as for leaks I can't promise anything, it's as seen, never ran the box myself so unsure bride seat now sold
