Jz automatic ring gear and automatic bel housing ideal for those wanting to make another gearbox fit £70 delivered anywhere in the uk jz front sump with oil pickup and baffle plate, pan needs bashed back out from car being low, £230 delivered anywhere in the uk {} {} {} 1jz non vvt soarer ignite this also works on 2jz gte engines, mkiv supra etc {} £80 delivered anywhere in the uk 1jz soarer jzz30 ecu, came out of my car prior to engine swap, ran good {} {} £150 delivered anywhere in the uk jz coil cover £60 delivered anywhere in the uk sytec fpr £50 delivered anywhere in the uk
