whats up guys looking for some help. I have a 94 e36 325i with abs. I wanted to make sure everything is right. I have my hydro taped in inline between the brake master and abs unit. I used the h port for the rear . Now it's works kinda but I Gota pull it super hard. I'm thinking it's a bleeding issue but not sure. If I'm going top of 1st gear whip it and try and do a 180 it's pretty hard it don't just lock up. I figured with the asd matched with a 5/8 master it should lock up super easy. The hand brake is pretty stiff and foot brakes feel good as well.
Not sure if correct but most diagrams for hydro show pluming after the abs unit. And the usual, a lot of bleeding.
Yeah I redid the plumbing and used a t connector and taped in under the car after the abs after bleeding the hydro is strong now I can lock up on pavement no problem. Big difference from having the lines taping in before and after the abs unit.
