318is - m42 engine 1.8 16valve Decatted exhaust Chipped ecu Ebay coilovers Polybushed rear subframe and trailing arms. Welded differential Stripped interior. Straight car but heavy lacquer peel, and some surface rust. Bought to use on track/drift, used once at curborough sprint track in the midlands and never used since, has been driven in and out of my work unit so it does run but idles high with a vacuum leak. It needs some work but would make a good drift car or track car, will need trailering away as no mot. V5 is present! Would make an ideal learner car/wall runner/reshell etc etc Looking for £500 which going by every other car on here lately is about £9500 underpriced. {} {} {} {} {}
