Has anybody used the det3 ecu on a ca18det or a rb20/5 z32 etc. Is there any issues with the cas signals to the ecu. I know a number of ecus don't work with nissan crank sensors. I'm basically looking for a decent cheap way of making some small adjustments to my map. It's currently stage 3 noz chipped. But I feel it would benefit massively from a little more timing and a slightly leaner fuel map.
http://fctuning.com/nistune/. Would be a much more cost effective and less time consuming solution mate and still give you OEM diagnostics to check upon things as and when you like.
