Regrettable sale of my ps13 but need to grow up for a bit and get a house. Ive built this from the ground up over the last 5years. Even down to having 90% of the bolts re zinc coated. This car has had no expense spared and only tbe finest Jdm parts fitted. Most of them brand new aswell. This is one of if not the most sorted and cleanest ps13 in the country. This build would be in excess of 30k to do so its a bargain at the price. Its show built but has all the mods to be a capable drift car and handles very well. Im not interested if you think its over priced. Im in no rush to sell but priced with room to haggle also. Heres what i can remember. Shell was fully stripped back. Undersealed with 3m Schultz. Front custom tubs and rears cut higher and lip added. New front end, all oem. Slam panel and behind lights. Added strut to fire wall strengthening aswell as spot welded seams. New front and rear oem window seals. Also new doors seals. Brick headlights brand new. Aswell as indicators and center grill. Bay painted in lancia gold and all welds blended. Body painted in ford frozen white. Will be mopped before sale. All bolts have been re zinc plated. Front and rear subframes re painted purple. Front rack moved forward 25mm. Engine only done 3-4k Sr20 black top from a 1996 type X *Weisco pistons *Oem rods and crank *New arp studs throughout *New bearings,thrust washers etc. Arp i believe *New oil pump & water pump *Fully balanced and lightened bottom end. *Os Gliken supersingle clutch(balanced to match the engine) *Hks 256 cams *Tomei adjustable cam sprockets (all dialled in) *Tomei RAS *Tomei arms turbo 7960 *Tomei manifold *Tomei elbow (new version) *Tomei baffled sump *Tomei oil block adapter *Splitfire coilpacks with splitfire d1 spec 24crt mounting plate *Hks top mount conversion rail with hks 680cc injectors and nismo fpr *Mcr factory rocker cover. Signed by masashi yokio of mcr factory and d1 driver for dmax *Kazama auto catchcan *Apexi coolant tank *Koyo 3layer copper rad with billion cap. *Billion super rad hoses *Billion power steering reservoir. *Greddy oilcooler with filter relocation. *Greddy intercooler kit with custom hot side to suit tomei turbo. *Greddy pulley set *Naprec lower power steering bracket with naprec oversized pulley. *Apexi intake kit for z32 afm. *Z32 afm. *Rare discontinued works 9 okutan ear drum wind breaker shot gun exhaust New decat pipe. Could do with the sytem tweaking to sit higher but doesnt scrape. All fuse boxes relocated to under the dash. *Battery relocated to the boot *Walbro Fuel pump Greddy OELD boost controller. Apexi PFC with commander. Mapped by Martin Battye Running aroubd 360bhp at 1.3 bar. Turbo capable of more. Chassis *Silk road coilovers with swift spring 12k/10k have spares to go with it of different rates. *Ikeya formula LCA's roll center correction. *Ikeya formula tie rods and ends. Roll center correction. *Moddified front knuckles. *Ikeya rear camber arm *Ikeya rear traction arms *Ikeya rear toe arms *Pbm rear solid subframe bushes with roll center correction. *Yashio factory front support braces. *Kts solid steering bushes *Uras strengthening lower member spacers. *Uprated front drop links *Two way diff in r200 casing (suspect nismo)with GTR drive shafts. *Front and rear strut braces. Brakes & wheels *Z32 calipers all round with endless pads * Z32 BMC and booster Braided hoses. * Brembo front discs redrilled to suit 4 stud. * Works CR01s in matte carbon. Big disk face 15×9j -41 with 195/60 15 uniroyal rainsports 15×10j -53 with 205/60 15 rainsports. Drivetrain Osgliken super single clutch(balanced to match engine) Nismo clutch pivot bolt Tomei super rare short shifter with kazama brass bush. Bodywork Full spirit rei kit (only one in europe) 65mm rei rear fenders ( blended) 45mm rei front fenders Rei roof spoiler Rei 3pc boot spoiler Origin type 2 cf bonnet with aerocatches. Rear crash bar and jack point Interior Bride brix driver seat (gen) Recaro dc2 passanger Nardi deep corn wheel Defi gauges oil temp and pressure, boost Nismo gear shifter Leather shifter boot and handbrake cover. Kts drift button Broadway rear mirror Type x black carpet Karo style chequered mats Alarm 3month old Clifford avantguard Alarm with remote start ( cost £850) As you can see the list is very extensive. The car attracts alot of attention where ever it goes. New owner will not be disapointed. Banzai mag are currently potentially interested in doing a feature aswell. Price £17,000 ovno. Car is located in taunton.
