Hi guys just taken this as PX for my 2jz E46 m3 drift car , drives fantastically you wouldn't think it has done 168k. Phoenix Yellow 2001 Non sunroof 4 Owners From New 168k FSH Black heated leather Harmon Kardon Supplied by Lind Bmw in Norwich 2001. Fully stamped original service booklet loads of history New pas pump, new clutch, recent full Insp 2 service inc diff & gear box oil. Also just had Oil and genuine filter. HSD Mono pros fitted Yellow Powerflex subframe bushes Reddish motorsport plate kit fitted Power flex black series bush kit fitted Ferodo ds2500 New OEM rear discs Braided brake lines all-round Race brake fluid dot 5 Full inspection 2 service inc diff oil Gear box oil replaced Short shift gear linkage fitted Oem new m gear knob Jack royal suede & leather steering wheel 18 inch genuine oem alloys Fedral rsr cut slick road legal tyres 235 front 265 rear Currently has rear seats removed but will come Oem interior Only Bad points are the lacquer peel on the roof, bonnet is slightly faded , bulb warning lights are on the dash and there is the usual slight m diff noise. £7000 {} {} {} {} {} {} {}
possible swap? depending on Chassis condition https://www.driftworks.com/forum/threads/6700-s14a-with-link-ecu-big-spec-road-legal.257374/
